Polaris EV owners?
/ Polaris EV owners? #1
Timark80
NW FL
78' Ford 2600 - 09' Bobcat T320 l
Yesterday I was at Sams Club and they had a new electric utv out front.
Did a search here but showed nothing.They're on the high $ side at $10999.
base price.It looks like the decked out price is around 14k!!
They seem to be a lot heavier duty than a golf cart.
The quietness and capacity are really appealing.
Anyone have one?
No,it's a Polaris Ranger EV.
I was asking if anyone here owns one.
/ Polaris EV owners? #5
I purchased a Polaris EV about 2 months ago, now have 46 hours on it. I use it every day for getting around, light chores, on our 10 acres. I find it useful & fun, novelty has not yet worn off.
The ride is comfortable, quiet, enough power & speed for me. It's rated 25mph, I rarely top 6mph, ride mostly on bush-hogged fields, tractor paths. The 50 mile range is way more than enough for a days use here.
The negative side is cost. Even with the 15% rebate for ag use from the state of California, the Polaris EV is going to be more costly in the long run than the same size Polaris 400 gas model. A new battery pack will be $1300 at current cost.
Another potential negative factor is excessive vehicle weight, 1750#, with the 650# of batteries. So far it has not seemed like a problem on dry ground, but I expect use on soggy ground will be more limited than a lighter UTV.
/ Polaris EV owners? #6
Just curious. How many hours can you expect before you have to replace the battery pack?
Steve
/ Polaris EV owners? #7
The Owners Manual says the battery pack can last 4 years or longer, depending on use. I believe the total amount of current drawn is more of a factor than hours of use. Also, deep, more complete, discharge will degrade, shorten battery life.
Batteries are US Battery 12v XC deep cycle.
I would like to ask if the $1300 battery replacement was from Polaris or any deep cycle battery?
Just curious...
Today I priced a new blue 2010 EV Ranger at $10755 total price out the door.
Tomorrow I will checkout the other dealer.
/ Polaris EV owners? #10
The $1300 figure was given by the Polaris dealer, when I asked what it might cost to replace the battery pack.
Just any 12v deep cycle battery might not work. I would make sure that the specs match the original, which is not the typical 12v deep cycle. Both the controller & on-board charger are programmed to match the power curve of the original battery pack.
They cost $1300 now in 2010,what will the price be in 2014 or 2015?
One "salesman" told me that any equivilant deep cycle battery should replace the original battery group.
Hmmm,Still researching...
/ Polaris EV owners? #12
Car dealers are not enthusiastic about taking used electric cars on trade because for resale the new purchaser will demand new batteries and they are as you mentioned very expensive. So after 3-5 years you are stuck with the electric vehicle because the dealers don't want them on their lot.
Another point. With the electric grid system under stress now, switching to electric utvs makes no sense as you are just increasing demand on a system that is already in trouble.
I like the concept of quiet running and ease of maintenance. Motor will probably out last owner. But at what cost and will more consumers move to this option in the future.
IMHO the golf cart is the answer. Smaller, lighter and made for casual use. But for a UTV, electric is the wrong solution.
/ Polaris EV owners? #13
I have an Polaris EV and think it's an excellent piece of equipment. I recently installed solar panels and produce a surplus of electricity so it was a good fit.
As far as someone's statement about an "overtaxed power grid" my suggestion is to charge it overnight when grid demand is low, unless you have solar power available.
The EV Ranger tows over 1200 pounds and I've had no trouble hauling stuff around with it over pretty hilly terrain on the VA/WV border. I normally don't even use the 4 wheel drive or low range unless I'm pulling a heavy load.
As far as replacing the batteries, I would think any good quality deep cycle batteries would work fine as long as they are matched. When I first built my place I was off-grid and used NAPA Stowaway batteries which were identical to a battery sold by a solar power company but a hundred bucks cheaper each. Those batteries have held up well over many years with proper maintenance.
/ Polaris EV owners? #14
You need to look at the converter to go from 48v-12v and the prices for the two extra batteries to just put a winch on the thing. Think I will keep the RTV for now.
David Kb7uns
/ Polaris EV owners? #15
Anyone have one?
I have a 2010 and it was the worst purchase ever. The batteries are over $2000. The EV's had defective chargers that weakened the batteries & Polaris will not do a thing to help. The charger was replaced under the extended warranty but the battery damage is not. Do Not buy it.
Caterpillar 910 Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 910...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
John Deere 6359DF (A64119)
John Deere 6359DF...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61573)
2012 Toyota Tundra...
