massey 461 first review
/ massey 461 first review #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Well got to try the tractor out for the first time this week and man its nice. The 201 perkins engine is so smooth and the low end grunt is amazing. I've ran a few of the new compact tractors that must run high rpm for power and there's no comparison. My 461 can actually idle and run in the upper gears without stalling. Thing is like a mini bulldozer. Guess that's the result of long stroke and big bore engine. Anyway its very maneuverable and the MWFD is awesome. The operator area is a little tight for big guys but not too bad. Overall its a very well built and heavy tractor unlike the new disposable Kubota type compacts. This is definitely one worth rebuilding after its normal wear life is over. I do have a issue with the used Massey 1055 loader as it has no down force but looking into how to fix that issue now.
/ massey 461 first review #2
Does the tractor have a combining valve on it??
Glad to hear you are happy.
df.
/ massey 461 first review #3
Hello there Sawtooth
Thanks for posting your review on that MF 461.Hope you get your issue resolved with your loader.Maybe look under search here on TBN and find solution.
If I may ask you a question :Which disposable Kubota type compacts are you refering to?Because I own a Kubota and I was hoping its not on your list. :)
Boone
Not sure what a combing if you can explain I will look. Sorry but first loader I've personally owned. Ran a few but didn't work on the mechanicals. Thanks
Now as for Kubota its probably one of the best quality fit and finish tractors I've seen. Haven't tried the 60 plus hp units but the smaller ones are good light tractors for easy transportation. However that benefit has a negative side by not being as structurally strong. Kubota also uses high revving engines which I don't personally care for but they are well made. I come from the old school of thought that likes low revving high torque motors with tons of lugging power. Anyway it depends on what you need and like. Besides all manufactures now make the lighter compact style tractor and Kubota may just make the best of those style of tractors. By the way my PTO speed is 1800 but my friends are 2800 on the Deere 990 and Kubota MX5100 I believe. Either way both work its just what you like.
/ massey 461 first review #5
Page 15, picture on the right, was an option on your tractor. You can combine the flow of both pumps for loader work.
http://http://www.masseyferguson.com/agco/mf/NA/Tractors/MF400/MF_400Series_Brochure.pdf
df.
That may be the issue on the speed of the loader, thanks. I don't think its hooked up that way though which may be why its slower than expected. I will have that option added later though. So if you combine the flow what do you loose? I'm assuming the option of running a hydraulic implement in the rear right?
Now how to fix the no downward force issue with the loader. Anyone with an idea?
/ massey 461 first review #7
Yeah, if you combine, you loose the rear hydraulics.
Keep us posted on the downpressure.
Any warranty left??
df.
Ok when you say loose its only the remotes right? If this is the case then that's good for me but if its the lift too then that sucks.
/ massey 461 first review #9
No, you lose the lift. It's actually designed to increase flow to the remotes for implements that require it, it cuts the lift out of the system and diverts it's flow to the remotes. The front end loader takes it's feed from the same system that powers the remotes so if you turn on the combiner valve you'll gain more flow to both your loader and your remotes.
Well that's not good for me. However no big deal just use it as is. For the guys that have a lot of loader experience does the 461 have good flow for loader work? Just curious if the 461 has slower than average flow or good flow. Maybe I have another issue if the loader should be pretty quick. I've used Deere 990 and couple kubotas in past that seemed quicker. Thank you
/ massey 461 first review #11
The loader may be slower than a similar sized compact, but the lift power & stability of the machine will be much greater. I didn't think the speed on them was awful, just needed to be run above an idle for better cycle times
Well i'm such an idiot. I didn't even think about the engine speed. This tractor is so strong at low RPM i decided to do most of my work in the 1000-1100 rpm range. No wonder the loader was slow. On the Kubota and Deere 990 i was running around 2000-2300 just to keep the power up. I couldn't believe it but i actually pulled a 7 1/2ft disk with 20" harrows totally sunk up idling in a higher gear. The Kubota MX5100 would just choke under these conditions. Little less hp but man feels like a lawn mower compared to this thing. Anyway, next time i'll idle up to 1600-1800rpm to see how it does.
thanks for the info.
/ massey 461 first review #13
Sawtooth
Sure like to see a pic or two of that "461" when you can get around to it. :thumbsup:
Boone
/ massey 461 first review #14
You may b bypassing in your cylinders. That loader should pick the front end of the tractor off the ground, if it wont id check your cylinders
Sawtooth
Boone
Well there i go again putting down Kubota when its really a great tractor. Sorry about that i'm just amazed at the power of this Massey. Their just made for different purposes. I tried to attach a picture so lets see if it works.
Sorry for the dumb question but how do i check my cylinders? Would like to do so if possible. Thank you
/ massey 461 first review #17
run tractor at 540 operating speed. place bucket flat on ground and roll your bucket down, it should lift the tractor off the ground if it dont then you prob have a blown seal. now check the lift cylinders by pointing the bucket straight down and puch ur loader down and this should also loft the front of the tractor off the ground
thanks guys for the help. As instructed i ran the rpms up a bit this time and all is well. Thing just has so much power i was basically idling as i was trying it the first go around.
