3rd scv, power beyond?
/ 3rd scv, power beyond? #1
rfraser
I have both power beyond and a 3rd scv installed on my 2520. Something just don't look right to me. I know the plumbing is wrong. Would any body have any pics or info on how this should look? Having to tie the 3rd scv valve open with something to get power beyong seems like a chessy way to design this. These are both options offered for this tractor and no where does it say you can't have both at the same time. This has been bugging me since I got this tractor. No straight answers from dealer.
Thanks.
/ 3rd scv, power beyond? #2
Welcome to TBN:D
You right, something does not sound correct. I do not see the fittings or bypass hose for the Power Beyond-I don't think it's installed;) Looks to me like only the 3rd SCV is installed.
/ 3rd scv, power beyond? #3
This is what the Power Beyond kit looks like:
/ 3rd scv, power beyond? #4
The way the power beyond works on the 2x20 series is through a loop. When you have the BH on for example you open up the loop hose and connect the quick connect on it to the BH. The end you removed the loop hose from goes on the other BH hose. When you take off the BH you reconnect the loop hose.
So you should have a female connect on the back of the tractor and the loop hose (male end) going into it. (The other end of the loop hose is permanently attached) You remove the loop hose male end from the female and this becomes your power beyond access.
Rob
/ 3rd scv, power beyond? #5
I can't verify this yet, but you may lose power beyond capability
when you install the 3rd SCV which uses the PB to supply oil to it.
anybody with a backhoe out there install the 3rd scv?
/ 3rd scv, power beyond? #6
Possibly. The JDParts drawing is very unclear-it even shows all the hoses connected to itself, sort of a "perpetual" valve I guess.:confused2:
I'm suprised I'm the first person to encounter this issue. It still appears to be a bit of a mystery.
/ 3rd scv, power beyond? #8
For the price of the JD kit, many have added a valves themselves to get usually two remotes instead of one. Add to that this kit was not available for a year or two after the tractor was released.
/ 3rd scv, power beyond? #9
You might want to check the 3x20 series drawings. I have the 3rd valve and the PB for my BH. The system is somewhat different but I haven't really looked at it yet. I did pull the BH off once to make sure there were no snags and I'll look more closely at it when I put the hoe back on after I'm done bush hogging. I can take some photos if you needto see the set up.
Rob
/ 3rd scv, power beyond? #10
Rob
Rob, the 3x20's are totally different...not even close.
/ 3rd scv, power beyond? #12
Can you post a bigger picture? And from more angles?
It kind of, maybe, looks like the power beyond supplies the 3rd SCV valve. In which case you'd have to remove the "wrapped" hoses from the scv valve to use the power beyond. But its near impossible to say from those pictures.
John Deere 5055E (A64126)
John Deere 5055E...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
300 Gal Fuel Tank (A64127)
300 Gal Fuel Tank...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
