Pole building construction pictures
   / Pole building construction pictures
Ok, thanks. Didn't know if you had to buy a special "nibbler" type tool. I'm assuming it worked ok for you.
I had a fine tooth metal blade and held it close to where I was cutting so it wouldn't flap. As I recall it went very smoothly.
Got the plywood up. Should I paint the plywood?
   / Pole building construction pictures #103
Lookin' sharp :thumbsup:
I paneled our interior walls with OSB - and I do plan on painting it (white) - largely for illumination reasons ....
I really do like the look of wood though .... and that plywood looks pretty nice (but a bit busy :D)
I just did a bunch of 2' x shelving in our garage with 3/4" B-C plywood .... and I polyurethaned them (3 coats, sanded 3 times) ... a good bit of work, but they will be easy to clean.
   / Pole building construction pictures #104
Paint it white, it will make the room feel bigger and help with illumination. Out of curiosity, how come you didn't cover the walls with the same metal panels as the ceiling?
I didn't realize how busy plywood looks. I used wood vs metal or drywall because I could hang stuff on the plywood. It also absorbs sound.
   / Pole building construction pictures #107
I would just like to know how you kept the shed so clear of "stuff" during your build. Seems like mine filled up the day before I built it!:D
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
