Pole building construction pictures
   / Pole building construction pictures
Ok, thanks. Didn't know if you had to buy a special "nibbler" type tool. I'm assuming it worked ok for you.
I had a fine tooth metal blade and held it close to where I was cutting so it wouldn't flap. As I recall it went very smoothly.
Got the plywood up. Should I paint the plywood?
   / Pole building construction pictures #103
Lookin' sharp :thumbsup:
I paneled our interior walls with OSB - and I do plan on painting it (white) - largely for illumination reasons ....
I really do like the look of wood though .... and that plywood looks pretty nice (but a bit busy :D)
I just did a bunch of 2' x shelving in our garage with 3/4" B-C plywood .... and I polyurethaned them (3 coats, sanded 3 times) ... a good bit of work, but they will be easy to clean.
   / Pole building construction pictures #104
Paint it white, it will make the room feel bigger and help with illumination. Out of curiosity, how come you didn't cover the walls with the same metal panels as the ceiling?
I didn't realize how busy plywood looks. I used wood vs metal or drywall because I could hang stuff on the plywood. It also absorbs sound.
   / Pole building construction pictures #107
I would just like to know how you kept the shed so clear of "stuff" during your build. Seems like mine filled up the day before I built it!:D
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Cushman Electric Cart (A55851)
Cushman Electric...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
