First time stuck - almost
/ First time stuck - almost #1
buck12
Mississippi
Kubota 5460HSTC
Took the tractor to the hunting camp this weekend to do a little road repair. After completing my work I thought I壇 take the tractor for a spin and check for turkey sign in a bottom. There is a loggers ford that crosses a shallow creek. When I approached the crossing it appeared dry. It appeared normal until my front tires sank axle deep in soupy sand. I guess a flood we had in early may washed in loose sand instead of the normally hard packed sand that can be easily crossed by truck or tractor. I immediately stopped locked the rear df and tried to back out but the R4s just spun. The loader was able to lift the front enough to put pieces of logs under the tires but still no luck. After about 45 minutes of trying to back out I tried forward and was able to cross the creek. The wide R4s basically floated across the soft sand while the narrow fronts sank. But was unable to make it up the opposite bank. Finally I put the tractor high range 3rd gear opened the throttle up pressed the df lock and was able to back out the way I came. I have stuck ATVs, motorcycles, lawnmowers, and trucks but having a tractor axle deep in sand with water oozing up was a bad feeling maybe even helpless feeling.
/ First time stuck - almost #2
The diff lock has gotten me out of a lot of situations. Another thing that can get you unstuck is to drop with FEL with the point down. Then curl it up to back out. Used this during the winter when I went too far off the pavement to dump a load of snow.
Ralph
/ First time stuck - almost #3
Ran into a problem the other day where it should have been a slam/dunk while falling a tree...Had to use the FEL bucket curl to help me back out of some soft ground that appeared to be ok...There's always something near or on your tractor you can use to get you back to good solid ground.
Don
Tried to use the loader curl technique but in the soupy sand it did no good.
/ First time stuck - almost #6
Another technique is to use a chain on the FEL (or forks in my case) attached to a tree or other solid object and then raise the FEL. Since the FEL gets closer to the tractor as it is raised the effect is to move forward a little bit at a time. Reset the chain and do it again, and again, and again....
It only works going forward, when the chain is attached fairly high on the object, and if there is plenty of time to mess with it.
Anything is better than walking away from the tractor however.
/ First time stuck - almost #7
I remember way back in the old days when Dad stuck our tractor. He attached a plank to a rear tire with a chain. Each rotation brought the plank through the muck and moved the tractor.
Ralph
Ralph
I remember my Granddad doing the same thing with a fence post.
/ First time stuck - almost #10
After I redid my driveway I hauled some of the old driveway rubble to my aunt's to build up her shore line. The water level was low. So I had the idea to drive on the lake bed around dock to where we were working to dump a couple hoppers.:D (you all know where this is going.) Had few large pieces on the FEL forks. Just a 100# or so. The hopper on the 3ph was 900#ish.
One spot was a little wet. I approached it carefully going in and made it through. Barely leaving a rut. Dumped the hoppers and started back. As soon as got to the wet area the front wheel dropped in to the axle. I knew right away I was stuck good. Fighting would only get me in deeper. Went and got an off cut of plywood and was able use it as a ski under the forks. Worked like a charm. Got right out. Thank God!
What I couldn't figure right off was how I made through the first time 1000# heavier. Later it dawned on me. Having all the weight on the 3ph countered the weight of the FEL on the small front wheels. Two lessons learned that day. 1. When stuck don't fight it till you have a plan. (A lesson I often forget). 2. Balance!
/ First time stuck - almost #11
There times fel can make it easy getting unstuck..log/rocks behind each rear tire,drop fel bucket edge to ground,than engage diff lock slowly back out while curling bucket..than there as you done,taking chance of getting belly hung tho.:(...but as long as you get unstuck thats good gut feeling. :)
/ First time stuck - almost #12
I wish I had a picture but the other day I was grading the edge of our pond and the back end of the tractor with blade attached slide down into the water. The edge of the pond is about 30% slope so it was steep. No matter what I did I could not get out. Finally had to get towed.
I do plan on getting stuck more in the future though!:D
/ First time stuck - almost #13
I had some "similar" fun in the woods the other day. Went into the woods across a swail fine, no issues. Coming back out, the backhoe dropped into the dirt (different approach angle) and stuck me solid. In my case, after scratching my head a bit, I realized I could "jack" the tractor with the stabilizers. Lifted it 6 inches, jambed planks under (un-hanging the backhoe) and off I went...
I definitely agree, when you get stuck, don't just try to force it out, and make matters worse!
-Tom
/ First time stuck - almost #14
Good thing you and/or your tractor didn't end up getting a bath. :laughing::laughing:
/ First time stuck - almost #15
Or you attach be hind you, lift the loader up then put it down and reset this will pull you backwards, and also put in low range and let the tires slowly spin till they grab. I have not done it but it is the same idea you have just in reverse.
/ First time stuck - almost #16
Nice ideas if I wasn't buried up over the axles already. I needed to go backward to get out of the muck. The last several days I have been filling that wet area in with rock and dirt... Still it was a learning curve for me..
/ First time stuck - almost #17
The problem in reverse is that there is a tractor (and operator) in the way of the chain when the bucket is lowered if the chain is attached behind the tractor and to the FEL.
/ First time stuck - almost #18
And the problem going forward is that you are increasing weight on the front of the tractor. It may or may not work, depending on the ground.
You may be able to route the chain around the bucket from the bottom with the bucket completely curled. Then dump the bucket as you drive forward.
Fence posts, logs, x-ties, etc. will work chained to the tires. But be carefull if you have fenders! Wasn't so bad on the Farmall H or similiar.
Or you may be able to chain your wheel to a tree and let the wheel winch you out.
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
