Planters Dry Fertilizer Not Working
/ Dry Fertilizer Not Working #1
granthill
Upstate NY
TN75DA
I have a White 5100 4 row planter and have been having a hard time getting the fertilizer flow rate correct. Everything on the planter is adjusted to put 180#'s per acre but the fertilizer seems to get crushed by the augers and it binds up and restricts the flow rate. I have taken everything apart and cleaned it in the off season and ensuring the augers were put back in correctly after removal. All of the parts are in excellent condition.
The fertilizer is dry when I dump it in the bins, but does not take too much time before it gets a hard shell on the top. Does anyone know how to control the moisture and why the fertilizer is being crushed by the augers and not being pushed out palletized? Is there a moisture problem with the fertilizer? Any suggestions would be greatly appreciated.
Thanks!
/ Dry Fertilizer Not Working #2
Thanks!
You will need tight fitting lids on the ferterlize hoppers, If you dont have them, plastic with a rubber band around to secure would work in a jam? Humidity from the air cannot get to the ferterlize. It will soak humidity in like a sponge. Ken Sweet
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2025 Hercules 14 Gun Safe (A61569)
2025 Hercules 14...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Arrow Quip 10' Corral Panel X 4 (A64047)
Arrow Quip 10'...
2021 MASCHIO GASPARDO CONDOR14 WHEEL RAKE (A62130)
2021 MASCHIO...
