My 11-yo well just quit
/ My 11-yo well just quit #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
Well, my well is not well.:thumbdown: This morning it worked for awhile and about 10:30 am it quit pumping. I checked and the thermal overload is popping on the motor controller. When I throw the pressure control to off, the thermal overload holds just fine, but as soon as I put it to the operate position the thermal overload button will pop in about 5 seconds. My guess is that the pump has bound up.:smiley_aafz:
I had this well drilled in July of 1999. It has worked continuously and flawlessly for almost 11 years. The pump is sitting at about 340' and the well is drilled down to 386'. Our water is perfect, no iron and soft, good tasting water. The pump is a Gould pump. I don't think there's any better one than that.
I called my driller and he has 7 calls ahead of me today, so it may be tomorrow or Monday before they can come out.:( In the meantime, we are getting water from a neighbor and may go to my in-laws for a shower or two if repair is delayed. I haven't taken any photos yet, but will do that as the repair goes forward.
Wish me luck.
/ My 11-yo well just quit #2
Do wish you luck. But the ol' pump goes eventually. Yours is about 50' deeper than mine. And I'm on my third pump in 40 years...17 on the first one, and 22 on the second one. When they put the second one down, I asked how long it would last. I was told an average of about 7 years (Gulp!). But it did 3 times better than that.
/ My 11-yo well just quit #3
Bummer. :(
Ours quit last fall. It lives at the bottom of the well so I had never seen it before. It was somewhere over 14 years old. Ours is only down about 60' though. Took them less than an hour to pull it, change it, drop it, flush it and adjust our pressure switches.
/ My 11-yo well just quit #4
Rural living can be expensive. Ours had to be replaced a few years ago to the tune of $800. Definitely not a DIY job. Good luck.
/ My 11-yo well just quit #5
I pulled mine last weekend. I kept getting sand in the screen for the washing machine. I pulled it myself (only 140'), and cut off about 4' of pipe to get the pump to sit higher in the well. I Could have cut off the top, but I was curious just how deep it was.
I have pulled and replaced quite a few pumps just after I graduated from HS. I helped my dad last year with his (probably was 20 yrs old.
350' sure is a haul. To do manually, you'd want at least 3 people.
/ My 11-yo well just quit #6
My well is just shy of 400ft, but the pressure of the aquifer pushes the water up our 4" well pipe to about 25' of the surface. we then use a pump to pull it from there. The pumps we use are exposed pumps, not in the well. They are shallow well pumps Dayton 1D878 Shallow Well Jet Pump
Funny how just down the road things are done differently.
Wish you luck with your well.
/ My 11-yo well just quit #7
Uh oh, my gould pump is now 11 yo.... :)
I have pulled mine twice so far, both times the electric cable failed due to rubbing the well side. Last time I pulled it (200') most of the way by myself by hand (about killed me) and had to have the wife help. You can rent a motorized puller, or rent a pulley that attaches to the top of the well and let you pull it from the side. 400' would be tough to pull by hand, without a few good strong friends.
/ My 11-yo well just quit #8
I didn't hear from my well company yesterday, so I will probably call them in a few minutes (after 8 am) to see if they work on Saturday or if I'll be waterless until Monday at least. I opened up the pump controller box, but I don't want to do anything else before they get here. I could use my tractor and loader with a pinch strap to pull the pump, but I don't want to do that. I can afford to have someone else do this and I'll be happy to sit on the sidelines and watch, then write a check.
I also know that I need a couple of things like the tank's pressure gage replaced. The pump pressure gage is stuck at 30 psi and has been that way for several years. Also the small pipe going into the bottom of the pressure switch is very rusty and might need to be replaced. The wiring is not up to professional electrician standards either, but that seems typical for well drillers in this area. I provided a breaker box and they wired the rest of this. Notice the controller has no safety ground attached to the box. This is the first time I've opened the box and discovered that.
This was a good excuse for me to clean out my wellhouse (with my wife's help) and my little concrete pad around the wellhead has seen better days. Oh yes, my garage door opener died while we were on vacation. It is flashing a code that says the logic board is dead. It won't reset itself when unplugged as instructed on the troubleshooting sheet. The price of the board is 1/2 the price of a new opener, so I have a new opener sitting in the garage.
Both the opener and the pump have failed after a hard thunderstorm that came through a few days before we got home from vacation. I'm wondering if lightning or a power surge might be responsible for both these failures. I can't find any evidence of anything burned, but it does seem fishy that both went within a week of each other. However, we water our large yard and our garden off this well. It's done double duty for many years and I just can't complain if I have to replace the pump because it wore out. I do think Goulds pumps are the best and I'll be replacing mine with as good a pump as I can get.
/ My 11-yo well just quit #10
Dang Jim,sorry you Mrs. doing some down time. :(
Yep now time to up grade we did 2 years ago,cost more because city had new guide lines since 1978...$$$'s :(
Once the water starts flowing from house nozzle/spray head you'll have peaceful feeling again.
/ My 11-yo well just quit #11
City living is more expensive. :D The city takes a bite every month while in the country you get hit with a big water or septic bill every once in awhile.
Our city water bills were from $50-$125 a month. And that was many years ago. Since then the city has raised rates and put in tier pricing to save water usage. Raleigh did the same thing and now they are having to raise the water rates. Again. Why? Because people are using less water. DUH that was the plan. But less water usage mean less dollars and the revenue generated is not covering the costs to run the water system.
Our only water/sewer costs for the last five years of country living has been $350 to pump the septic tank and install a riser to one of the lids on the tank. And whatever the power costs to run the pump. Cheaper and better water and service than we had in the city. I would rather have iron in the water than Chlorine and the other chemical they are using to treat the water.:D
I do dread the day of having to replace our pump..... Partly for the money. Mainly for the hassle of not having water. :laughing:
Later,
Dan
/ My 11-yo well just quit #12
Jim, sorry to hear the news. Hope they get you pumping again soon.
Will be watching for "by the numbers" pictures.
I'm keeping my fingers crossed that my pump will last longer than my wife and I.
Thought it was gone a couple of weeks ago, but called my well man and he reminded me of two reset buttons on the bottom the the box.... Hotdog, click click, water running again.
/ My 11-yo well just quit #13
I will suggest that you look at GRUNDFOS SQFLEX pumps before making a choice.
These are the only pumps that drillers are now installing around here. The beauty of these pumps is that they will run on almost any kind of power AC/DC 30 to 300 volts. If power is down you can run them on almost any kind of generator or even batteries if you have to. Mine runs on 48v volt solar panels but can be run on a generator if the need arises.
/ My 11-yo well just quit #14
per the documentation for the SQF series pumps, the motor itself is a DC motor.
on the other hand, the control unit which you have to have for it, has an inverter built into it and can take either DC or AC input. but it still outputs DC only to the motor.
The pictures I posted this morning will have to do. The well repairman was here about 15 minutes. He replaced the motor control box and the pump fired right up and runs perfectly, $202 total bill. YIPPEE!:D The sound of a flushing toilet is music to my ears.:thumbsup:
Oh yes. . .thanks to everyone for the good thoughts. It always helps to have good karma.:)
/ My 11-yo well just quit #16
I agree. My water alone last year cost an average of $45.79 a month but when you include the drainage fee, sewer, and garbage pickup (all on the same bill), it was over $100 a month.:(
/ My 11-yo well just quit #17
Morning Jim,
Sorry to hear about the well. One suggestion I might make if you are having things redone. If room allows enlarge the amount of tank capacity in the well house. Well pumps are good for only so many on/off cycles. They can run nearly indefinately, but cycling kills them. The greater the tank capacity, the fewer cycles the pump needs to make and the longer their life will typically be.
Talk to your well contractor and see what he thinks.
/ My 11-yo well just quit #19
Good news on the well.
Ours has had issues before with wires rubbing on rock, and wearing thru. We also had a 2500 gallon tank put in, with a booster/demand pump.
Only problem now, is we would have no indication of the well itself failing, except for our tank running dry. Need to figure that out, because it would be nice to have that 2500 gallon reserve when the well pump goes...
As you mentioned, it is nice to be able to flush the toilet. You can get drinking water(bottled), can go take a shower at the neighbors or the gym. But you can only doo so much before the toilet has to flush :eek:
Well, I got so "pumped" after the well turned out so easy to fix that I jumped in my garage and put in my new belt-driven garage door opener. Wow! Is that thing ever quiet.:thumbsup: Two successful fixes in one day has me thinkin' I should buy a lottery ticket. Actually, I think it's 2-1/2 fixes. My Kubota G1800 lawn tractor had a dead dash panel the last time I used it. I have a starter button rigged so I don't need the ignition key to start it. It ran, but I don't think the battery was charging. I guess I had enough fuel in the tank that the fuel pump didn't even have to work. Well this morning I found the fusible link was toast. I replaced it and everything again works fine. I suppose I probably shorted something out while doing maintenance the last time. Anyhow, this has been a good day because while I was typing this post, my neighbor who I've done some boxblade work for recently stopped by and dropped off 5 gallons of diesel fuel. Maybe I should quit while I'm ahead and just chill out with a cool one and watch a baseball game. I don't want to take a chance on messing up a streak of good luck like this.:D
