Rear Blade Why doesn't my rear blade cut?
   / Why doesn't my rear blade cut? #21
Any chance of pictures of your blade hitched up to your tractor? 5-600lbs should work ok. My first rear blade weighed 680lb I think, it would roll the dirt as in the picture. No a lighter blade is not going to work as well with harder ground, but you say that your ground is shovel soft, most any blade should be working. Your boom should be just about parallel to the ground. The blade should be built so that the cutting edge is pretty close to the correct angle to be cutting most material.
Some pics of my first rear blade
   / Why doesn't my rear blade cut? #22
Brian,
I get similar results with my Deere 45 blade as you have posted. I think it is an adjustment/leveling issue with dcrylics blade. My blade is a little lighter than his blade.
   / Why doesn't my rear blade cut? #23
Hey, Something is wrong with those pictures, WHERE are the rocks? That setup is doing a beautiful job. Ken Sweet
   / Why doesn't my rear blade cut? #24
Rocks, what are rocks? We don't have any stinking rocks around here. :D I did that ditch for a temporary water line, about 18-20" deep. If I remember right, that was about a 90 minute job, dug, plumbed and back filled, for 240'. :thumbsup:
   / Why doesn't my rear blade cut? #25
Very nice pics, :) they show so much. Never mind the rocks, no boulders or stumps??? :D:D
   / Why doesn't my rear blade cut? #26
I can only wish, unfortunately, we have only a few trees and cutting one down may get you shot, BY ME. We do have a few boulders though. How big does a rock have to be before it is considered a boulder? :confused2:
   / Why doesn't my rear blade cut? #27
To quilify as a boulder around here it needs to be big enough to hide behind when playing "Cowboys and Indians".:D
   / Why doesn't my rear blade cut? #28
OK, then we have three different outcroppings, each spaced 1/4-3/8-1/2 mile apart. We have a few that would take a D8 or bigger to move.
I have the boom flail mower I've been working on hooked up right now, but I plan to unload it in the next day or so - so that I can hook up and get pictures of the blade. Should have pix by the weekend.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
