My Special Chainsaw Cart
   / My Special Chainsaw Cart #21
Very nice work Rob! I like how there's a place for everything. After looking at the front boxes and the shape, I have an idea for you. With some black plastic water pipe and a little canvas, you can have the best 'covered wagon' chainsaw cart around. :)
   / My Special Chainsaw Cart #22
And don't forget the miniature donkeys to hitch to it!:laughing: Also the chuck box on the back! Would make a great parade entry!:thumbsup:
More good ideas guys, thank you!
Great cart its a very cool idea having different job specific tops should save time and make things easier. I have a couple of questions, how much does the unit weigh when loaded and is it stable in off canter situations. My 4-wheeler weighs about 600# and I fear having the cart leading the horse. Thanks Mark
Hi Mark,
I estimate the wagon fully loaded like you see weighs in at just over 120lbs.
It pulls by hand very easily and no sweat behind the ATV at all. I have not loaded it full with firewood or rocks yet, but I don't think it would ever reach the max weight capacity! It is very stable with the wheel base being about 36" wide. I have not had it on any steep sideways slopes though ... but my driveway and trails have 15% slopes or more. No trouble on those at all.
   / My Special Chainsaw Cart #24
I used those Harbor Freight tires which were on sale for $9.99 and I already had 2 for some reason?
I have the same ones on my Special Firewood Cart. They leak down so I filled them with tire sealant goop.
Very nice work, Rob. I especially like the machine work on the trailer
tongue and steering mechanism.
What is it with those Chinese pneumatic tires, anyway? I have a bunch
of those like yours, and they ALL leak down. I just bought a 32 OZ
bottle of Slime sealant....I hope that works, cuz they ALL need it.
Same with the cheapo inner tubes, BTW. I have a bunch that cost as
little as $3-4 each, but they leak, too!
Hi Dave,
I get those cheapo tires because they are cheap.:D
That slime worked on the others I have (so far), so not a bad investment after all...
BTW, all my Chinese rubber stuff is very poorly made. My tractor rubber boots and seals all needed to be replaced. I had to put slime into that dump trailer tires as well.
   / My Special Chainsaw Cart #26
Rob, As usual, another work of art! I could really use one too! Thanks for sharing it with us. Brian
   / My Special Chainsaw Cart #27
Wow only 120# and seems very stable,you have some real good ideas and are a good source for inspiration. thanks Mark
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
Yanmar YFL-1575 33HP Utility Loader Tractor (A49461)
Yanmar YFL-1575...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
