Cutting into a bank....??
   / Cutting into a bank....?? #1
scoutcub
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
No, not the one with money in it....
Will be building a garage next to a house, and have to cut into a slope (bank) to put it in. Any ideas on how far back I should leave the bank behind the garage? 1'? 3'? Should I put a retaining wall up? Pros/Cons? This isn't my retirement home, and will be excavating the site with my TLB, and doing everything else I can to save $$$. All input welcome!
   / Cutting into a bank....?? #2
We need more information (e.g. slope height, soil type, how long of a cut, how much space behind the garage is available for cutting back) before we can even begin to offer any suggestions.
   / Cutting into a bank....?? #3
If I understand your question, you want to dig into a slope below your house to start a garage. My house is in the building stage, but take a look at this photo and see if this fits. The wall is for my lower patio, but It could be the start of a building wall if you wanted. THe builder installed a french drain behind the wall to keep water drained out> It seems you could do something similar as long as you had no underground utilities. OF course, you would need to put up the retaining wall during dry conditions and immediately upon digging out. I am building the retaining wall to hold the slab for the house. Seems that you could do the same as long as the soil type will not slough off and allow you to dig straight vertical wall. Leave enough room to install drain tile behind the retaining wall, pour a good footer that goes below the frost line and at least 16" wide with embedded rebar to set inside each CMU block in at least every other hole, fill each block hole with grout and you should have a good retaining wall.
   / Cutting into a bank....?? #4
You are talking how much space between the garage and the hillside? How are you going to mow it? What kind of mower do you have? How high is the hillside going to be?
How much room for water drainage? (that's a function of how high the hillside is and what is above it.)
Myself, I'd leave about ten feet, plenty of room to get the mower through. It also leaves room for the hillside to slump some before it stabilizes (depends on your soil and weather conditions.)
Ken
   / Cutting into a bank....?? #5
We need more info to be precise, but I would leave as much room as I could behind the garage for mowing and water drainage. Install a perforated drain pipe between the hill and your garage and run it to daylight. I would avoid the retaining wall and just try to slope the hillside if possible.
   / Cutting into a bank....?? #6
Most slopes can handle a 30 degree angle. The problem even with that is slump once it starts to rain. Put a retaining wall in and allow for drainage no matter what you do.
   / Cutting into a bank....?? #7
Get an engineer to design a retaining wall for you if it is over 4' high.
The required strength of a retaining wall increases as the cube of its height.
A 5' wall needs to be twice as strong as a 4' wall, a 6' wall needs to be over three times as strong. If the wall is not drained properly it can easily fail from that source also.
Designing a retaining wall by guess and by golly sometimes results in real life failures.
My neighbor had a "professional" stack concrete blocks (2' x 2' x 4') four high to make a retaining wall. It fell down that winter. I calculated how much he needed to set each block back from the one below to get a good wall, but he just had the same guy stack them right on top of each other again. Fell down again the next winter. Then he stacked them with some setback and drain rock behind them and they are still standing 3 years later.
OK, some more info, and pics. I went back down this past weekend, and it is ROUGHLY a 6' rise in terrain per 30'. I really don't want the added expense of a retaining wall, unless it's absolutely necessary. I can cut the bank back farther if need be. But, I'm worried about water runoff. I will put a drain system around the back of the garage. Looking at conventional construction for the garage, approx 30X30. garage will be going between the two vehicles in the pics.
Fire away!
   / Cutting into a bank....?? #9
There is lots of good info here, but it looks to me like
the question has already been answered. Behind the
house is a beautiful retaining wall. Wouldn't you
would want something similar behind the garage? or
combine them into 1 long wall?
How tall is that retaining wall behind the house?
   / Cutting into a bank....?? #10
I wouldn't worry too much about it. We put in a pole barn for the RV last summer. I had to cut into a hillside like yours, but a bit steeper and higher. I cut back ten feet beyond the barn and then sloped the ground away from the barn, about one foot in the 10' distance. Water drains down the hill into the swale and away from the barn into the swale. The ten foot gives me plenty of room to mow between the barn and the bank.
I sloped the bank low enough that I can mow it.
I would not bother with a retaining wall or drain tile.
Ken
2018 John Deere 460E Articulated Dump Truck (A52128)
2018 John Deere...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
