Transmission sheared gears
/ Transmission sheared gears #62
Aaron, if your air cleaner pics are correct, he either has a 16oo or a lot of non-1500 parts on his tractor.
/ Transmission sheared gears #63
I would be very curious what the serial numbers are on the side of the trans. I cannot find even one YM that does not have a diff lock. There are too many differences, IMHO.
Mike
/ Transmission sheared gears #64
Our air cleaner picture is correct. His picture does look like a 1600/1700/1900 engine. None of those have a 2 piece pinion gear though & all Yanmars have a diff lock.
Edit: Ohhh... I think he was just using a picture that Careyo63 originally posted of his tractor.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Transmission sheared gears #65
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
So . . . the plot thickens;). Why won't normal Ym1500 parts fit on his tractor:confused:?
/ Transmission sheared gears #66
Sorry Guys My bad:rolleyes: I believe I was just trying to give him a idea of how to go about seeing how the TS works. I think:confused:
Carey
Here are some pictures of my engine. No holes on top of the valve cover. Only holes on the side. Had to straighten the bracket for it to work
I also took some pics of where the diff lock would be. No lever, or anything.
Greg
Here are some more
/ Transmission sheared gears #69
I'm a believer:confused:, must be a really early model. Valve cover is certainly different, and if there were a diff lock, the shaft should exit the case right above the brake. Is there a plugged hole there?
/ Transmission sheared gears #70
I reiterate that I would really like to see the serial number stamped on the left side of the transmission case. By the left ankle when you are sitting on the tractor. In a clear spot should be a number which "should" start with "YM"
Mike
/ Transmission sheared gears #71
Here's an example (my Yanmar). The transmission serial number is highlighted at the center of the photo.
OK Here is a picture of the serial number on the tranny.
It says 1500D - 00301
/ Transmission sheared gears #74
Is that cast in, or stamped?
I thought they all started with YM, YM1500D etc.
If that #301 is the production sequence then it seems to be one of the earliest ones. Does anyone know when production began on these?
/ Transmission sheared gears #76
Does anyone know when production began on these?[/QUOTE said:
i believe they ran from 1975 to 1979. that is what some of the papers state that i had gotten with mine.
