Transmission sheared gears
/ Transmission sheared gears #21
what Norm said will help alot.Try L.M.T.C.I got one for my 1610D from them on a C.D. russ
I got a Parts Manual from Little Miami, ...thanks for the heads up.... they are great people over there! :)
/ Transmission sheared gears #23
"Posted by jerry on Monday, January 11, 2010:
I have a YM1500 minus an engine I would sell cheap.I'am located in Georgia.It has good transmission and rearend with great tires,wheels and sheetmetal.
Jerry"
You might check with this guy on SSB.
Normde how much for the tractor and where in Georgia are you located?
/ Transmission sheared gears #24
Yeah Norm
Just were at in Ga. are you this time of year. Hummm! still average of Mid to low 30's going to warm up a little this week but My Guess is REALLY FAR SOUTH :p:D:D I've had all I can stand already. Come on Spring!!!
Carey
/ Transmission sheared gears #25
Yeah Norm
Carey
I have a farm in Trenton, just up the road from Rome, but I'm in Ft Lauderdale now. You would have to email Jerry for that price, turnerbend.
I too sent an email to Jerry, but no response
Greg
Well, I bought a used transmission today for $300 plus shipping. It is being shipped to me from out west. With the price of individual gears....this seemed like the smartest option. I will keep you posted on the progress.
Thanks again for all your help
Greg
I was missing a few of the ball bearings in the 4x4 shaft. It is easy for them just to fall out. So I thought I would pass on that there is a seller on ebay that sells the 8mm bearing balls really cheap. I bought 25 of them for $6 with free shipping. I couldnt find them anywhere elso for that price.
Hopefully my transmission arrives soon
Greg
/ Transmission sheared gears #30
Greg
They may be too big, should have 5/16 balls.
Danny
I measured the ones I had with my digital caliper. They were 8mm on the nose. Wouldn't they have to be metric since these tractors are Japanese?
Greg
/ Transmission sheared gears #32
im with you G.. i was thinking that as i read danny's post i was thinking why would a Jap made tractor have 5/16 balls? But nothing amazes me that much anymore my 30 yr old chevy seems to even have metric on it?
/ Transmission sheared gears #33
The Japanese parts book even lists 5/16 in the description.
5/16" = 7.9375 millimeters
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
I will see how the 8mm fit when they arrive. The 5/16 marking might just be that they listed the closest english equivalent. I think they are so close in size anyway, that there will not be an issue. They probably came with 8mm from the factory but can but either size can be used.
/ Transmission sheared gears #35
Quick and rough calculations puts the 8mm .002 of an inch larger than the 5/16--if they do not fit or bind up then you will have to get the smaller ones. :rolleyes:
Remember the parts manual is in Japanese there is no need for the "nearest equivalent" as it is for the Japanese market and Japanese repair centers. The dealers are right on this.
Mike
/ Transmission sheared gears #36
I believe Aaron is quoting directly from published conversion charts. That makes the 8mm .00625" smaller than the 5/16", which may or may not make a difference.
Well, the tractor is back together. Everything works great! The transmission I bought was a little different than mine, so I had to swap a few additional gears to get everything to work right. Drove her around for a while today.
Did some wiring too. Put in a new fuse block and wired the back lights to blink simultaneously (like hazard lights)
I ordered a new seat and am in the market for a steering wheel.
Also, the 8mm bearing balls worked fine too. The 4x4 shaft slipped right on.
Thanks for all your help guys.
Greg
One more question for you guys
The key switch has a counter clockwise mode (you have to hold it...spring like action) Is this for tractors with glowplugs...Mine does not have glow plugs. Or is it for something else
Also, the lights on the dash are oil pressure and coolant temp right? But which is which
Greg
/ Transmission sheared gears #39
The key going to the left is for your thermostart. You can go to search and type in thermostart and find out all about it. My gauges on a YM2002D are probably different than yours. The middle section of my dash has 4 lights. top left is battery water level, top right is oil pressure, bottom left is coolant level (overflow bottle), bottom right is charge light. Yours might be different.
Vanguard V215-PH 4WD Articulating Heavy Haul Agricultural Tractor (A66734)
Vanguard V215-PH...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
2026 BIG TEX DUMP TRAILER (A67714)
2026 BIG TEX DUMP...
2011 STEPHENS 200BBL CRUDE TANKER (A67714)
2011 STEPHENS...
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
