Transmission sheared gears
/ Transmission sheared gears #1
gsdavis1
Cleveland, OHIO
John Deere 855
I just picked up a 1500 D with some sheared gears in the transmission. Does anyone know of any one looking to get rid of a used transmission? The tranny is all apart, I could maybe just replace the broken pieces, but the problem is that I did not take it apart...I got it that way...so re-assembly will be a challenge.
Also, is it possible to replace the current transmission with a power shift?
Thanks
Greg in North East Ohio
pastor@southwestbaptist.org
/ Transmission sheared gears #2
You can try LMTC or Little Miami Tractor Co. He is about as good as it gets esp.for your area. Sound like a very unusual trans. problem I would see what he has to say.
Carey
/ Transmission sheared gears #3
"Posted by jerry on Monday, January 11, 2010:
I have a YM1500 minus an engine I would sell cheap.I'am located in Georgia.It has good transmission and rearend with great tires,wheels and sheetmetal.
Jerry"
You might check with this guy on SSB.
Thanks for the replies guys.
I left a message at Little Miami
Also...what is SSB?
Greg
/ Transmission sheared gears #5
SSB is a discussion forum much like this one. The link Norm posted will take you to where you can email the author (Jerry) of that post.
Also, will a transmission from a 1500 fit a 1500 D?
Greg
/ Transmission sheared gears #7
It might but the 4 wheel drive model has some different parts inside. You may want to go to Hoye's website and look at the diagrams in the catalog. There is a link to Hoye's website at the top of the page.
/ Transmission sheared gears #8
Greg
Most of the time you will be better off rebuilding your transmission, if you use a YM1500 transmission, the gears that you will have to change out may just be the gears that are bad in your old transmission, so you are no better off. You could buy a YM 1500D transmission, but that won't be cheap. I don't have a YM1500D transmission, but I may have parts to repair yours.
Danny
/ Transmission sheared gears #9
/ Transmission sheared gears #10
Do I believe you need 4wd. In Ohio NO. Just deepends on what you plan to do with it.I use to live just out of Cinn. The 1500 in Ga. is sounding better might want to check into that and see if it is still available.If you plan on doing it yourself may come out better doing a split or a motor swap. I can make Cinn. in 7hrs. driving easy just something to think about. You will also have alot of spare parts left over that may come in handy one day or sell them to someone who may need them. With all the VN. recons around the area the spare parts may be a hot commodity;)
Carey
OK
I was going through the diagrams and the parts I need...but one big problem...
My pinion shaft and gear are NOT like the diagrams I found for a 1500D
The transmission is stamped YM1500D, but my pinion shaft is not held on with a nut and the pinion gear is not machined into the shaft, it is splined and just slips on..
Here is a video of my pinion shaft and gear.
YouTube - video-2010-01-13-16-00-17
Here is the page with the diagram from Hoye Tractor.
http://www.hoyetractor.com/CATALOG/1500/5-GEARS.jpg
Can someone help?
/ Transmission sheared gears #12
That is not a YM1500 part. Not only because of the nut & removable pinion gear but because of the design & number of the other gears also. You said you got that already unassembled. Is it possible that someone mixed up the parts from some other tractor?
I think you already called in but we do have a transmission for the "green" style.
BUT.... I dont think a new YM1500 transmission will even help. Your pinion gear cut is all wrong. You said earlier that your pinion gear meshed with your ring gear perfectly. The correct YM1500 pinion gear does not look anything like that (it is spiral cut) and won't mesh with your existing (straight cut) ring gear.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
I dont think the parts got mixed up. The pinion shaft is the exact length for the case and the machined shaft is the exact size for the bearings... I would guess that is highly unlikely to find another tractor with those specs.
Also, the pinion gear does mesh very well with the ring gear in the rear end. The tranny case says "00301". Could it be that this early production run came with something a little different from the factory?
Greg
OK, if you check this link showing the exploded diagram from Hoye's site
I know that I am going to need parts number...
3
25
27
13
18
19
Anyone have some of these available?
Also, does anyone have the description of the parts in the diagram....sometimes it is tough to tell if some are orings, snap rings or washers just from the picture.
My address is pastor@southwestbaptist.org
Thanks
Greg
/ Transmission sheared gears #16
If you click on the reference # on Hoyes drawing it will give you part info.
I tried that... and for a lot of the parts, this is what I get
Sorry, this product is not listed on our website yet.
With over 40,000 Yanmar parts in stock we probably have
it though. Please contact us and we can send you a link to
the product's page as well as pricing and availability
Greg
/ Transmission sheared gears #18
Your absolutely right. If you will contact Hoyes I'm confident they will be able to help you. They are fine folks to deal with.
/ Transmission sheared gears #19
Get yourself a OEM YM1500/1500D parts book. The nomenclature will be in Japanese, but the part #'s are in Arabic, (English), which is all you need to order parts.
OK, here are some part numbers of what I must have to be up and running...if anyone has these, please shoot me an email.
194190-26170
194190-26222
194190-26512
194190-26541
By the way...everyone here has been extremely helpful.
This message board is great!!
Greg
(2) 480/70R28 TIRES W/ 8 LUG RIMS (A64280)
(2) 480/70R28...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
PALLET OF APPROX (12) 2" X 6" X 55 1/2" TUBING (A64280)
PALLET OF APPROX...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
300 GALLON FUEL TANK W/MANUAL PUMP (A64281)
300 GALLON FUEL...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
