new 128 owner questions
/ new 128 owner questions #1
drillbender
Missouri
JD B, A, 1010, Ford 1710
I just purchased a 128 with these attachments; tiller, mower deck, moldboard plow, a wood chipper and a front blade. Only the front blade and the tiller show signs of much use. Also it has a manual lift and the low range transmission.
The seller threw in a John Deere hydrostatic drive with a mower deck attached.
The JD runs and seems to be OK except it looks a little rough, OK very rough. I was told it has the same engine as the cub. The seller said the cub needs a carb kit otherwise it is OK. As it is it won't start.
I paid the guy $1,000 for the whole setup. The guy has been out of work for 18 months so I didn't feel like trying to get him to lower his price. My plans are to restore the 128 as much as I can. It looks like it mostly need repainting.
Now first question. Was this price way out of line?
Second question. The engine is a Kohler 301 any recommendations where one can find carb kits? There is nobody here locally that sells parts.
Thanks in advance,
Bob B.
/ new 128 owner questions #2
Thanks in advance,
Bob B.
Bob,
Great find!! I'm a fellow Cub Cadet owner and I can assure you that it is a great machine that you will enjoy for years to come. I own and operate a Cub 122 with the same K301a motor that you have. When well tuned it has a lot of power and can be tuned for more if desired.
Price is truely relative to the owner but it sounds like you got quite a few attachments and options which makes it a lot better deal. The 'creeper gear' option alone is a couple of hundred bucks if you had to buy it seperate.
There is a wealth of information, parts and retrofit attachments out there for these machines. I'll pm you with some more information that may help you with specifics.
Good luck!
Brian
/ new 128 owner questions #3
A carb kit should be a common item and available at any NAPA, JD dealer, or cub dealer or any shop that sells anything Kohler. If you can't find it locally, try http://www.partstree.com
AJ
Thanks Brian and AJ. As soon as I get the 128 Home I will post a before picture. Weather permitting I will try and get it next week end.
Bob B.
/ new 128 owner questions #5
I think you got a good deal......good luck and have fun
/ new 128 owner questions #6
You got a heck of a good buy! The JD should have a version of the K-series engine depending on its age.
Thanks in advance,
Bob B.
/ new 128 owner questions #7
You got a great deal I have seen where the wood chippers alone go for $500
Generac Speedwash Pressure Washer (A65640)
Generac Speedwash...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
Skid Steer Rotary Cutter (A65640)
Skid Steer Rotary...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
