new 128 owner questions
   / new 128 owner questions #1
drillbender
Missouri
JD B, A, 1010, Ford 1710
I just purchased a 128 with these attachments; tiller, mower deck, moldboard plow, a wood chipper and a front blade. Only the front blade and the tiller show signs of much use. Also it has a manual lift and the low range transmission.
The seller threw in a John Deere hydrostatic drive with a mower deck attached.
The JD runs and seems to be OK except it looks a little rough, OK very rough. I was told it has the same engine as the cub. The seller said the cub needs a carb kit otherwise it is OK. As it is it won't start.
I paid the guy $1,000 for the whole setup. The guy has been out of work for 18 months so I didn't feel like trying to get him to lower his price. My plans are to restore the 128 as much as I can. It looks like it mostly need repainting.
Now first question. Was this price way out of line?
Second question. The engine is a Kohler 301 any recommendations where one can find carb kits? There is nobody here locally that sells parts.
Thanks in advance,
Bob B.
   / new 128 owner questions #2
Thanks in advance,
Bob B.
Bob,
Great find!! I'm a fellow Cub Cadet owner and I can assure you that it is a great machine that you will enjoy for years to come. I own and operate a Cub 122 with the same K301a motor that you have. When well tuned it has a lot of power and can be tuned for more if desired.
Price is truely relative to the owner but it sounds like you got quite a few attachments and options which makes it a lot better deal. The 'creeper gear' option alone is a couple of hundred bucks if you had to buy it seperate.
There is a wealth of information, parts and retrofit attachments out there for these machines. I'll pm you with some more information that may help you with specifics.
Good luck!
Brian
   / new 128 owner questions #3
A carb kit should be a common item and available at any NAPA, JD dealer, or cub dealer or any shop that sells anything Kohler. If you can't find it locally, try http://www.partstree.com
AJ
Thanks Brian and AJ. As soon as I get the 128 Home I will post a before picture. Weather permitting I will try and get it next week end.
Bob B.
   / new 128 owner questions #5
I think you got a good deal......good luck and have fun
   / new 128 owner questions #6
You got a heck of a good buy! The JD should have a version of the K-series engine depending on its age.
Thanks in advance,
Bob B.
   / new 128 owner questions #7
You got a great deal I have seen where the wood chippers alone go for $500
16MM Spool Of Cable (A47477)
16MM Spool Of...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2020 FREIGHTLINER...
2012 BOBCAT E80 EXCAVATOR (A52707)
2012 BOBCAT E80...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
