Winches How to winch 4300?
/ How to winch 4300? #21
...........Notice that I said STRAP, as in nylon that will stretch, not CHAIN. ...............
I use chain because it does NOT stretch, and does not build up energy that will be released quickly if something breaks and that strap acts like a powerful slingshot.
If nothing breaks, then all is fine.
Some use the stretch so they can jerk at the stuck equipment or whatever they are pulling. Jerking or getting a run at it is not a sensible thing to do, and causes things to over stress and break.
/ How to winch 4300? #22
I was able to get the tractor out Saturday. It wasn't nearly as hard as I thought it would be; conversely getting my truck out was much harder than I expected.
I ended up using a 6x6 timber under the bucket to raise the front end and fill in the front ruts with some spare wheels. I then attached chains to the eyes on the bottom of the loader bracket; maybe that is the weight rack. The bucket was then lowered with it tilted up sled-like. Pulling with my winch about six feet got the front end onto firmer ground. I was worried about pulling too much with the HST, so I then drove the tractor out using the bucket to pull me along until the tires found enough traction.
I think it looked a whole lot more stuck then it was. The loader can really help out as long as there is something for it to push against. Without it I would have had to winch much further than I did.
JP
Good news JP;)
In the future, put the gearshift lever in neutral, that will disconnect the drivetrain from the tranny.
The range shift shaft is broken. I received the parts to repair on Monday, so hopefully I'll be able to get range selection working.
/ How to winch 4300? #24
That's a feature of rental tractors....sometimes it is intentionally set up
that way. And the shift shaft is a bit fragile.
Which rental yard did you buy from? Maybe the same one I work with.
/ How to winch 4300? #25
The "rental" kit only locks out C range, A, B and neutral are still available.
JP, Look at THIS long thread on the fix for the shifter...
There is a remnant of a riveted strap across the 'C' range throw of the shifter. I suspect that was quickly bypassed by renters. I'd hoped the linkage had just been removed to thwart hot rod renters and that the bellcrank and shaft were still intact. Alas, upon inspection the shaft was broken and the bellcrank missing.
I read the shift repair thread over a couple of times before decided to purchase. I think the broken range shift and maybe a high dealer repair cost was reflected in the purchase price. I got the tractor, 420 loader, JD-something tiller, and Land Pride box for $3900. I carefully read and re-read dfkrug's rebuild thread until I was confident I could fix anything that might pop up.
I'm missing everything from the actual shift lever forward, so I bought all the external parts from JD. I bought a chrome plated, 5/8" solid shaft from McMaster-Carr along with a couple different types of shaft seals. Hopefully I'll be able to tackle it this weekend and I'll start a new thread with my results. If it works out as I hope, this should be cheap, easy fix.
I think it was in "B" range when I bought it because it was hella slow for loader work. I was able to drill and tap the remaining shaft enough to turn it into 'C' range. If I hadn't gotten stuck, I could have knocked out my project in no time.
Funny, I read your thread a least a dozen times and I never noticed the "A Tool Shed" stickers. That's where I got mine.
/ How to winch 4300? #28
You keep saying "720" loader-It must be a 420...
yeah, I kept typing 720 into search fields too. Some weird neural connection going on there or maybe its just that the 7 is just above the 4 on the keypad... corrected now.
/ How to winch 4300? #30
Our favorite rental yard has used several ways of locking out high speed
capability on different tractors over the years. On my first Kubotas, they
just whacked off the range shift lever. On the JD955s, they welded a
plate over the slot that the shifter moved it. My 4300 was in many pieces
and no range lockout was apparent. I did have the broken shaft, as we
know.
I did two things to improve the range shifter mechanism. I DID use the
stock shaft, but I replaced the detent spring with a softer one inside the
shift fork. I also installed an O-ring between my new bellcrank and the
gearcase. It is quite snug and should exclude water from getting in there.
My shifter shifts very easily, but not too easily...I was concerned about that.
As for the labels, I have removed most of them, but here is one I will not:
http://www.tractorbynet.com/forums/...-john-deere-4300-complete-rebuild-orig_1a.jpg
/ How to winch 4300? #31
Did you have a ballast box or implement on the 3-pt? I ask because you mentioned
the load on the front tires creating ruts which made me think you were using
the tractor without rear wheels weights, filled tires, and/or some weight on the
3-pt.
We moved up from the 4100 HST to the 3520. When the first heavy snow of the season
happened, I was out-of-town. I get a call from my wife saying my son had
taken the tractor out with the FEL to do some snow removal.
He plowed down the sloping drive and turned around to make a pass coming up
the driveway and couldn't make it up the slope - the drive wheels would spin.
The first question I asked was did you put the ballast box on the 3-pt. They
backed the tractor up the driveway and hooked the ballast box to the 3-pt.
Problem solved.
My other son has buried the 3520 in the wetlands twice, but knew to
use the FEL to lift and push the tractor backwards. He, too, ventured out
without the ballast box both times.
Glad you were able to get the tractor out and your truck. Reading your posts,
I had this vision of your stomping about, muttering to yourself. I think anyone
who posts here has been in a like situation.
Take care and be safe. I miss Monterey....
Cheers!
Lon
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Massey Ferguson 285 Loader Tractor (A66285)
Massey Ferguson...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
