Winches How to winch 4300?
/ How to winch 4300? #1
jpinca
Member
South San Francisco Bay, CA
JD 2000 4300 HST 4WD
I buried my 4300 to both axles in mud and now I need to winch it out. Where is the safest winch points, front and rear? I have a 720 loader attached.
Thanks.
JP
/ How to winch 4300? #2
Get a shovel and dig for the rear drawbar. Presumably you drove it forward to where it is now. Pull it out backwards. If it is really planted and you got foolish, you could pull the front axle out from under it by hooking there.
/ How to winch 4300? #3
If you search around here a bit you'll find a few getting unstuck tricks. Are you using the front end loader to help, like using the bucket to push it backwards and lifting the front tires up to get some blocking under them?
/ How to winch 4300? #4
I agree, the drawbar is the best pulling point.
/ How to winch 4300? #6
Pictures and where are you located at? You might be able to get some help from us :)
/ How to winch 4300? #7
You could use the loader to downforce and get the front tires up enough to put wood under them. Also if there is anything solid to anchor to you could use the bucket curl and raise to pull yourself out. That's what I did last time I buried mine.
Not much mud around here this time of year...
/ How to winch 4300? #8
Thanks.
JP
I really love you guys that jump in here and join when you get into trouble. You give us nothing to go on and expect us to preform miracles over the net. We work on facts, like are you in the middle of a river, lake, carnberry bog, cow pasture or your septic tank in the back yard. Help us and we can help you better.
/ How to winch 4300? #9
I love this forum because members will bring there experience and knowledge to help another member in trouble, but Deerlope, your being a little harsh on ''jpinca'', I think. The guy only ask where was the safest place to hook-up the winch. Jmo.
/ How to winch 4300? #10
Septic tank. lol
Reminds of the time I had the trencher going, burying a water line....hit the septic line. All **** broke loose. I had to break out the backhoe and dig a HUGE hole because I broke a "Y" in the line, under a road, right next to the tank.
About the time I've got the hole about 4 feet deep and 10 feet in diameter, my wife pulls up....:eek:
/ How to winch 4300? #11
I love this forum because members will bring there experience and knowledge to help another member in trouble, but Deerlope, your being a little harsh on ''jpinca'', I think. The guy only ask where was the safest place to hook-up the winch. Jmo.[/QUOT
Sorry! I am always willing to help but I need all the facts.
Hmm, I thought that was enough "facts" for the simple question at hand. I wasn't asking how to recover, although I'm appreciative of any helpful advice. I figured brevity was the best. But, for anyone interested in the whole epic:
I just bought the tractor and joined the forum, so I haven't had a chance to fill out the signature line. This forum was very helpful in my decision to buy this tractor and I plan to repair the range shift using info gleaned here.
I'm in the south San Fransisco Bay. We've been getting a tremendous amount of rain here and this is my first winter in my new-to-me house. The lot is pretty level with poor drainage. I've been doing some foundation and gutter drain work, but these things never get fully tested until it actually rains (only a few months of the year here). I'm filling in a drywell with drain rock that was delivered on the other side of the property. The 720 loader is working much better than I'd expected and seems to handle a full bucket fine. I'm no longer bummed its not a 730.
The load on the front tires, however quickly wore down major ruts in the saturated silt/clay soil. On one my return trips the front end found a hole and sunk. In retrospect, I should have stopped and assessed the situation, but this little tractor had been darn near unstoppable until this point. I proceeded to bury the both axles. The loader had gotten me moving before, but the ground was so soupy then it couldn't really help this time.
The tractor is now about fifty feet from, and pointed toward, my gravel driveway.
Against my better judgment and in a race against the next rain storm, I brought in my F350 to pull out the tractor backwards. Well, now my truck is stuck further in. Learning my lesson, I didn't bury it and just walked about disgusted.
I now have a 12k winch on my Bronco. First course is to retrieve the F350 and use it as a second anchor point. I plan to bring in some timbers and raise the front with the loader then pull straight ahead.Then pull out the tractor. I have a snatch block, so 24k of force is on tap hence my concern about winch points.
The loader mount look stout, but are they the best choice?
I could try winching backward as there is a big pine tree about 150 feet to the rear, but that would require driving into the quagmire again.
No pics just yet, but I plan to get some for posterity.
So back to the original question: what are the stoutest front/rear winch points for a 4300 w 720 loader.
Thanks.
JP
/ How to winch 4300? #13
Thanks.
JP
Welcome to the forum.
From the front I'd put chain around the weight bar (under the FEL latching plate).
From the rear, the drawbar.
Are there any attachments on the 3 ph.
You must have the 420 loader?
/ How to winch 4300? #15
There is away to get out by chaining a timber to each wheel but unless you have seen this done don't try it. There is some flicks on youtube with a guy doing it. I have with good result attached a chain thru and around the tire and the other end around a tree or some other anchor. You will only pull yourself whatever the tire measures across, then rehook and do it again. As said the drawbar pulling rearward is the strongest point to hook to. Just be sure to use a steady pull, no quick snaps. Hope all works out good for you and I should not have been so short with you.
Now that you mention it, I've heard of doing that and probably would have tried it had I thought of it at the time. I have the lumber and the chain. This is my first tractor and I'm still learning while trying to get a job done too.
No hard feelings.
JP
/ How to winch 4300? #18
You go careful with that tractor. Even us guys that have been use them since we was knee high to a grasshopper have accidents.
/ How to winch 4300? #19
I generally hook a strap to the front weight plate but for most pulls I pass it under the bucket, then up around it to the hook on top. I then lower the bucket to the "tobaggan" position and use it to reduce the weight on the front wheels. The pull of the strap will actually try to lift the front.
Notice that I said STRAP, as in nylon that will stretch, not CHAIN. (although I do use short sections of GOOD chain to fasten the strap if needed).
I use an 8000lb winch and snatch block but more to give better control and a lighter current draw than to give 16000lbs of pull.
Make sure that you either have a helper giving the tractor a little bit of "go pedal" or find the neutral point on the shift lever so you are not fighting the hydrostat. Don't let the helper dig deeper ruts, just roll UP and forward as the winch does the work.
I was able to get the tractor out Saturday. It wasn't nearly as hard as I thought it would be; conversely getting my truck out was much harder than I expected.
I ended up using a 6x6 timber under the bucket to raise the front end and fill in the front ruts with some spare wheels. I then attached chains to the eyes on the bottom of the loader bracket; maybe that is the weight rack. The bucket was then lowered with it tilted up sled-like. Pulling with my winch about six feet got the front end onto firmer ground. I was worried about pulling too much with the HST, so I then drove the tractor out using the bucket to pull me along until the tires found enough traction.
I think it looked a whole lot more stuck then it was. The loader can really help out as long as there is something for it to push against. Without it I would have had to winch much further than I did.
JP
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
2021 International HX620 Quint Dump (A62613)
2021 International...
