Electric Question
   / Electric Question #1
riptides
Super Member
Northern Virginia
Kubota ZTR, RTV, MX6000
So I wake up yesterday and parts of my house are without power. I look for a circuit breaker that tripped and found none. I flipped them anyway and still no power. Although when I flipped a suspect breaker back on, for a second I get a light in one room on the first floor. Then nothing, and the circuit breaker is not tripped.
So I start looking for any GFI's inline. Well, really cannot find any on that circuit. I think. I really don't know what the run looks like. So outside I go, on the second floor I find some GFI's tripped and cannot reset them. What the hey?
So now I am thinking I got two lines with issues. Or one big mess of a circuit. Since GFI's usually, my understanding go downstream, I am hoping the circuit breaker or breakers may be faulty.
What say you, what do you all think.
And I am calling in an electrician because I just don't mess with power. But I would like to understand it more.
   / Electric Question #2
Glad to hear your getting an electrician, electricity can be a real head ache and could easily cause death. I would suggest watching asking following{without getting in the way} your electrician around. When the electrician finds the problem he/she should fill you in on what happened.
   / Electric Question #3
This may not even be close to the cause of your situation but several times over the years my Father would get calls for something similar. On some of those occasions we would find that there was a loose connections outside, where your service entrance wire that goes up the side of your house, connects to the power line coming in from the street. If this is the cause of your problem and this is a BIG if. One side of your panel is dead or getting an intermitant feed. As wind moves the overhead wires the connection opens / closes. It may sound a little farfetched but it does happen.
Have the electriction check check both legs of your service entrance for power. This is one of those process of elimination jobs. If everything checks out at the panel and out to the street, then you start looking the other direction.
The reason you can't reset theose GFI outlets you mentioned is because the outlet is currently dead as in no power. Good luck and let us know what you discover.
   / Electric Question #4
I have never had to replace a GFI breaker, but many years ago, our house had a GFI breaker in the master panel in the garage and it would kick off any time I tried to use my electric razor in the bathroom. I finally decided I'd buy a new breaker, but when I went to get it, I was fortunate enough to find a knowledgeable salesman who asked questions, told me it was very unusual for one to go bad, what I should check first, etc. That breaker controlled the outlets in 2 bathrooms and an outdoor outlet by the front door and one by the back door. I simply removed the covers from those outlets, blew the cobwebs out with my air compressor, and put the covers back on. Problem solved.
   / Electric Question #5
Calling the Electrician is a wise move. They have instuments for tracing circuits that makes life much easier.:D
Last year I smelled something like burned electrical insulation. Found a very hot fuse box that was probably installed in 1934 when the house was built. [When we bought the house I though it was inoperational.] Traced down the circuit and breaker in the modern but mainly unlabeled main box. The electrician came and installed a new connection box to replace the fuses and then installed a GFI box inline just down stream from the main box. No room in the main box for the GFI. All is happy since.:D
   / Electric Question
I have been there. Since this place is a demolition/remodel I opted to replace all electric and plumbing. Parts of the place are over 100 years old. I was amazed and dismayed that people would actually do some of the things we found when inspecting the electric runs. I was actually surprized to find a basic extension cord running under tacked carpet into a wall outlet that then fed another wall outlet.
I am hoping with the extreme cold, that something just stretched, or I am thinking that maybe one of my flood light banks has a short. The floods have been burning bulbs at a strange rate.
We shall see. I am just disappointed, since the electric is really only two years "new".
   / Electric Question #7
If you are burning bulbs at a strange rate you might have lost a neutral causing high voltage to the bulbs do you have a volt meter?
   / Electric Question #8
I had a similar problem in my detached shop that is powered by it's own D/B underground service, Mine turned out to be low voltage on one of the hot legs.
A 2 inch section of the large 4-O wire oxidized to the point of just one 14GA strand left. apparently there was a nick in the insulation that let water in.
The cable was all swollen up and powderized.
   / Electric Question #9
Bird, That's some shaver! sure you're not shaving with an electric weed eater...:D
I have had problems with fire ants getting into panels ,sub panels, ac units. It's the first thing I look for if it isn't an obvious problem now. My cousin has been a HVAC guy all his life, said he gets this problem allot since the fire ants have moved in. He swears they are some how attracted to the power?? Don't know if that's true but, I have had short out and found "fried" ants...
   / Electric Question #10
Sounds like you have a GFI that is working correctly, and there is a "fault" leaking off power to a ground somewhere. They trip off when there is any imbalance between the hot line and the neutral line.
Un-plug everything down-line and see if the GFI's can be reset.
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
