3520 / 300cx raise prob
/ 3520 / 300cx raise prob #1
Chris robinson
i have a jd 3520 w/300cx loader e-hydro and the loader bucket won't raise up over apprx. 36". it happened once before I loaded it up and took it to my dealer and when I took it off the trlr and cycled it up it raised to max highth , had it serviced and about 6 hrs later it is doing it again. any one experienced the same prob ?
/ 3520 / 300cx raise prob #2
No but it could be due to a bad pump that is performing intermittently?
/ 3520 / 300cx raise prob #3
Disconnect and and reconnect your FEL hydraulic quick connects. Once on my 3320 I had popped one loose running over some brush, and the FEL would only lift a couple of feet and then stop like it hit something. I thought I had broken something for sure. I looked around and saw one of the QCs just barely popped off its seat. Pushed it back on and problem solved.
/ 3520 / 300cx raise prob #4
Welcome to TBN Chris:D
I suspect Cocre is onto the problem. Slightly unseated QD's are usually the first cause of problems like this. The other is low fluid level-but that would not be intermittent.
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
