3520 / 300cx raise prob
   / 3520 / 300cx raise prob #1
Chris robinson
i have a jd 3520 w/300cx loader e-hydro and the loader bucket won't raise up over apprx. 36". it happened once before I loaded it up and took it to my dealer and when I took it off the trlr and cycled it up it raised to max highth , had it serviced and about 6 hrs later it is doing it again. any one experienced the same prob ?
   / 3520 / 300cx raise prob #2
No but it could be due to a bad pump that is performing intermittently?
   / 3520 / 300cx raise prob #3
Disconnect and and reconnect your FEL hydraulic quick connects. Once on my 3320 I had popped one loose running over some brush, and the FEL would only lift a couple of feet and then stop like it hit something. I thought I had broken something for sure. I looked around and saw one of the QCs just barely popped off its seat. Pushed it back on and problem solved.
   / 3520 / 300cx raise prob #4
Welcome to TBN Chris:D
I suspect Cocre is onto the problem. Slightly unseated QD's are usually the first cause of problems like this. The other is low fluid level-but that would not be intermittent.
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
35in Tooth Excavator Bucket (A55787)
35in Tooth...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
Informational Lot - Financing (A55218)
Informational Lot...
