3520 / 300cx raise prob
   / 3520 / 300cx raise prob #1
Chris robinson
i have a jd 3520 w/300cx loader e-hydro and the loader bucket won't raise up over apprx. 36". it happened once before I loaded it up and took it to my dealer and when I took it off the trlr and cycled it up it raised to max highth , had it serviced and about 6 hrs later it is doing it again. any one experienced the same prob ?
   / 3520 / 300cx raise prob #2
No but it could be due to a bad pump that is performing intermittently?
   / 3520 / 300cx raise prob #3
Disconnect and and reconnect your FEL hydraulic quick connects. Once on my 3320 I had popped one loose running over some brush, and the FEL would only lift a couple of feet and then stop like it hit something. I thought I had broken something for sure. I looked around and saw one of the QCs just barely popped off its seat. Pushed it back on and problem solved.
   / 3520 / 300cx raise prob #4
Welcome to TBN Chris:D
I suspect Cocre is onto the problem. Slightly unseated QD's are usually the first cause of problems like this. The other is low fluid level-but that would not be intermittent.
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2016 Sakai SV540 Padfoot Compact Roller (A54865)
2016 Sakai SV540...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
