3520 / 300cx raise prob
   / 3520 / 300cx raise prob #1
Chris robinson
i have a jd 3520 w/300cx loader e-hydro and the loader bucket won't raise up over apprx. 36". it happened once before I loaded it up and took it to my dealer and when I took it off the trlr and cycled it up it raised to max highth , had it serviced and about 6 hrs later it is doing it again. any one experienced the same prob ?
   / 3520 / 300cx raise prob #2
No but it could be due to a bad pump that is performing intermittently?
   / 3520 / 300cx raise prob #3
Disconnect and and reconnect your FEL hydraulic quick connects. Once on my 3320 I had popped one loose running over some brush, and the FEL would only lift a couple of feet and then stop like it hit something. I thought I had broken something for sure. I looked around and saw one of the QCs just barely popped off its seat. Pushed it back on and problem solved.
   / 3520 / 300cx raise prob #4
Welcome to TBN Chris:D
I suspect Cocre is onto the problem. Slightly unseated QD's are usually the first cause of problems like this. The other is low fluid level-but that would not be intermittent.
UNUSED WOLVERINE PFF2-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Electric Forklift Pallet (A50322)
Electric Forklift...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
ASCO Transfer Switch (A52377)
ASCO Transfer...
