Snow Equipment Owning/Operating Snow Removal
/ Snow Removal #1
macmax55
2009 Kubota L3540HSTC w/ Cab 1978 Wheel Horse C-141 8 speed 2003 Deere L110 Automatic
Hi All,
We have had about 2 big snow's where i live. I have been using the LA854 loader on my Kubota L5240HSTC to do it. I love the fact that i can stack snow, but at the same time it is killing my driveway. I am not sure if i should look into a snow pusher, loader mounted plow, regular plow, or snowblower. What do you guys suggest???????????
/ Snow Removal #2
The more you get regularly, the better a blower looks. With infrequent snow I would just use what you already own. With occasional snow, probably some kind of plow. I am in the first category.
/ Snow Removal
Cool thanx,
BTW what model is your tractor?
/ Snow Removal #4
I use a plow the front of my FEL. I also have a 7' Woods Grader Blade on the 3 point but not shown in this pic. Works good for me on my gravel drive.
These pictures are a 18" dump we got last year.
Chris
/ Snow Removal
That really cool,
who is the plow made by?
/ Snow Removal #6
I put the plow on the tractor frame, not the FEL.
There are many different ways to do it.
/ Snow Removal #8
I am on the look out for a 6 foot plow blade myself to make a snow pusher out of for my B7800. I do not want to give up my loader in the winter and a pusher would serve me better.
/ Snow Removal #9
There some good second hand plows for sale,plows have adjustable shoes/skids not to tear up driveways to much.
Snow blower,lot less work also spring time clean up.
/ Snow Removal #10
If your snows are really infrequent I'd just suggest more careful use of the loader - the long recent thread on a section of ABS pipe on the scraper edge may be an inexpensive way to start.
/ Snow Removal #11
Sounds to me that you need to allow a base to set up on your driveway.
Next time you get up to 3 or 4 inches of snow use your vehicle to pack it down. Don't plow it.
Does your ground freeze or you in a region where freeze and thaw happens November through March.??
It's all about keeping your plow edge above grade.
/ Snow Removal #13
Hi All,
Do you have a bucket level indicator.?? This would help a lot, if you don't.
/ Snow Removal #14
Hi All,
For CT you probably don't need a snow blower as long as you have room on the sides to pile snow. For those locals where they get huge dump after huge dump, they pretty much need a blower, as there's only so high you can bank snow.
Don't know what else to recommend to you besides the loader, I have front frame mounted plow new to me this year, I have a rear blade also. For a few years I used my loader with high volume bucket, which in effect acts as a scooping lift-able/loadable pusher box.
If I had to choose just one of those 3 mentioned, I would go with the loader.
You say your tearing up your driveway, are you using Float on your loader? If gravel drive then float and nose up just a hair and you should be ok.
/ Snow Removal #15
Here is a couple more of my complete setup. We got 3" more today so I was just playing. Sorry for the poor quality, took the pics with the cell.
The combo of the front 7' Snow Plow and the 7' Woods Rear Grader Blade work great.
Chris
/ Snow Removal
I find that the float on the LA854 doesn't put enough ground force down and it is leave little bits of snow behind
/ Snow Removal
Our ground is frozen from about Novemver right through March
/ Snow Removal #18
This is the only equipment I can use when the driveway gets snowed in & the Kubota can't handle it.
/ Snow Removal
I would do that but my girlfriend drives a FWD car and its a real pain to get in in 3-4 inches of snow
/ Snow Removal
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
RAYTREE RMPP680 HYD POST POUNDER (A64277)
RAYTREE RMPP680...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
