Rancher ESP shifting
/ Rancher ESP shifting #1
whistlepig
Elite Member
Preble County, Ohio
Kubota B7800 with FEL
My old true blue 2000 Rancher is getting hard to shift. It sometimes sticks between gears and has to be rocked to shift sometimes. I replaced the shift angle sensor last year and that helped a lot. Have any of you guys had shifting problems with the ESP transmission?
/ Rancher ESP shifting #2
check the up/down buttons on the handlebars. Ive had the switches in there pack with dirt. Cleaning them out fixed it
Does the gear indicator blank out when you have problems?
could be water in the connectors for the angle sensor,.clean it out with contact cleaner and pack with dielectric grease.
Those were the places i had trouble on my ESP honda.
The gear indicator does blank out when I have problems. I have checked and cleaned the switches as you suggested. The angle sensor is dry and has never been wet. I thank you very much for your suggestions. Something seems to be growing weaker but I can't figure out what it is. The ESP seems to need a good boost to shift. It's missing something.
/ Rancher ESP shifting #4
Battery fully charged? Mine acts up if my batt is weak and needs replacing.
Terminals on the battery clean?
At first glance id go with the angle sensor, but since you replaced it recently its less likely.
Does it happen at the end of a long, high speed run? or just around the house.
ES is a good system, but it has a tendency to have its share of electical gremlins.
I think theres a way to have the indicator flash trouble codes IIRC. But for the life of me i cant remember how to get the computer to do it.
/ Rancher ESP shifting #5
I agree, a weak charged battery would be a good bet. It's a pretty easy thing to check before going any further.
Could be the battery. In the winter she just runs it about 10 minutes to put out hay for the horses. I'm sure 10 minutes isn't enough time to recharge the battery.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
BOUROUGHS 300 GALLON SPRAYER (A64278)
BOUROUGHS 300...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2021 CATERPILLAR 302.7D CR EXCAVATOR (A65053)
2021 CATERPILLAR...
