need help getting wifi and broadband working
/ need help getting wifi and broadband working
He uses Sprint broadband when out of the office for internet access. When in house or at home he uses the local wireless network instead of Sprint. He is having trouble switching from one to the other.
though for the last 30 hours it is behaving correctly.. WEIRD!
soundguy
/ need help getting wifi and broadband working #22
The software for the aircard needs to also take control of the WiFi connection.
I think this is the problem...
Generally,Window's applications look for "any available" when seeking an internet connections i.e., web browser, mail client etc. etc...
In order to maintain a connection the client computer must maintain an IP address (usually assigned by a modem/router/accesss point)...when the computer is switched between ISPs (i.e., sprint/DSL) the IP address must also be switched...Windows is not always good at recognizing that a new/different ISP is connected and does not always release and renew the IP address...
Ususally restarting the computer will accomplish the task or it can be done manually several different ways... there are automatied batch programs that have desktop interface shortcuts or it can be done from a command line interface... (from a CLI enter "ipconfig -h quotes)
Another alternative is to manually set up the connections for each service provider and assign both preferred DNS servers as well as IP, Subnet, and Gateway data...(not sure if this can be done with the Sprint service)
/ need help getting wifi and broadband working #23
Ususally restarting the computer will accomplish the task or it can be done manually several different ways... there are automatied batch programs that have desktop interface shortcuts or it can be done from a command line interface... (from a CLI enter "onfig -ho quotes)
Did you mean
Code:
ipconfig /release and then ipconfig /renew
Those work for most any windows system..
Aaron Z
I have been restarting between the swaps.. but so far.. after last night.. it -seems- to have started working like it suposed to.
soundguy
/ need help getting wifi and broadband working #25
Yes, sorry...not sure why I didn't see the typo...I meant "ipconfig"
yes those two commands should work...
hopefully I won't need them :)
soundguy
well, all looks good.. I have used the laptop on broadband all day.. ow here at home I turend wifi back on.. it found the network and auto connected in about 20 seconds.. and is downloading some java software in he ackground.
not sure what the issue was the other night.. but ( fingers crosed / knock n wood ) seems to be ok now.
thanks for all the help guys.
soundguy
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
3148 (A63117)
3148 (A63117)
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
