water in tires
/ water in tires #1
johnvickl
bought kubota 7040 it has water and antifreeze in rear tires want to remove and put in multiseal. do i have to get all of water out? thanks
/ water in tires #2
Are you having leaks? I've not heard of using multiseal in full size tractors. (I'm assuming that is one of these products that seals small to medium size punctures)
/ water in tires
no leaks, kubota tells me the multiseal works great for thorn punctures etc. everything in south texas will stick you. i had slaime put in my last tractor thanks,, john
/ water in tires #4
I guess I'm just not familiar with Texas sized thorns. I have R4 tires and cannot imagine what kind of pre historic dino thorn would be needed to puncture them.
If I were in your shoes though I would remove the water as the viscosity of the slime type substance is important in forming a seal and you wouldn't want to dilute it. I'd guess the manufacturer could give you advice too.
/ water in tires #5
i think i'd wait til i had a leak before i changed anything, who knows you may never have a puncture at all.
/ water in tires
thanks for your help i will leave the water and antifreeze in until something wierd happens thanks
/ water in tires #8
Locust thorns here in Texas can grow to several inches long. Finding a thorn longer than your hand is common. Mesquite are not large compared to Locust.
/ water in tires #9
We get some gnarly thorns here - choke cherries get some pretty long ones that can puncture an ag tire when they hit it right. I filled my front tires with foam when I put my second set on the rims. I highly recommend that.
When you puncture one of your water filled tires it'll probably act like a squirt gun. It's pretty easy to spot the hole :). Don't ask me how I know...
LILLISTON 4R ROLLING CULTIVATOR (BOWED BAR) (A63745)
LILLISTON 4R...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
TANK MANIFOLD (A58216)
John Deere 7230 (A62180)
John Deere 7230...
300 Gallon Fuel Tank (A62183)
300 Gallon Fuel...
2012 International 4300 Reefer Truck (A63118)
2012 International...
