water in tires
   / water in tires #1
johnvickl
bought kubota 7040 it has water and antifreeze in rear tires want to remove and put in multiseal. do i have to get all of water out? thanks
   / water in tires #2
Are you having leaks? I've not heard of using multiseal in full size tractors. (I'm assuming that is one of these products that seals small to medium size punctures)
   / water in tires
no leaks, kubota tells me the multiseal works great for thorn punctures etc. everything in south texas will stick you. i had slaime put in my last tractor thanks,, john
   / water in tires #4
I guess I'm just not familiar with Texas sized thorns. I have R4 tires and cannot imagine what kind of pre historic dino thorn would be needed to puncture them.
If I were in your shoes though I would remove the water as the viscosity of the slime type substance is important in forming a seal and you wouldn't want to dilute it. I'd guess the manufacturer could give you advice too.
   / water in tires #5
i think i'd wait til i had a leak before i changed anything, who knows you may never have a puncture at all.
   / water in tires
thanks for your help i will leave the water and antifreeze in until something wierd happens thanks
   / water in tires #8
Locust thorns here in Texas can grow to several inches long. Finding a thorn longer than your hand is common. Mesquite are not large compared to Locust.
   / water in tires #9
We get some gnarly thorns here - choke cherries get some pretty long ones that can puncture an ag tire when they hit it right. I filled my front tires with foam when I put my second set on the rims. I highly recommend that.
When you puncture one of your water filled tires it'll probably act like a squirt gun. It's pretty easy to spot the hole :). Don't ask me how I know...
2011 Kia Forte Sedan (A51694)
2011 Kia Forte...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
2025 380 Mini Track Loader Stand-On Skid Steer (A53421)
2025 380 Mini...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
