water in tires
   / water in tires #1
johnvickl
bought kubota 7040 it has water and antifreeze in rear tires want to remove and put in multiseal. do i have to get all of water out? thanks
   / water in tires #2
Are you having leaks? I've not heard of using multiseal in full size tractors. (I'm assuming that is one of these products that seals small to medium size punctures)
   / water in tires
no leaks, kubota tells me the multiseal works great for thorn punctures etc. everything in south texas will stick you. i had slaime put in my last tractor thanks,, john
   / water in tires #4
I guess I'm just not familiar with Texas sized thorns. I have R4 tires and cannot imagine what kind of pre historic dino thorn would be needed to puncture them.
If I were in your shoes though I would remove the water as the viscosity of the slime type substance is important in forming a seal and you wouldn't want to dilute it. I'd guess the manufacturer could give you advice too.
   / water in tires #5
i think i'd wait til i had a leak before i changed anything, who knows you may never have a puncture at all.
   / water in tires
thanks for your help i will leave the water and antifreeze in until something wierd happens thanks
   / water in tires #8
Locust thorns here in Texas can grow to several inches long. Finding a thorn longer than your hand is common. Mesquite are not large compared to Locust.
   / water in tires #9
We get some gnarly thorns here - choke cherries get some pretty long ones that can puncture an ag tire when they hit it right. I filled my front tires with foam when I put my second set on the rims. I highly recommend that.
When you puncture one of your water filled tires it'll probably act like a squirt gun. It's pretty easy to spot the hole :). Don't ask me how I know...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
Electric Mobility Scooter (A51694)
Electric Mobility...
100 FUEL TANK (A53843)
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
