1979 ford 3600 worth
/ 1979 ford 3600 worth #1
vafaarmboy
Ford 3600
I have a 1979 Ford 3600. We bought new. Thinking about selling it. Would like to know what it is worth. All metal good. Repainted years ago. Square fenders, two rear remotes, new tires. Wheel weights, live pto, power steering, Dunham lehm/ farmland 22 loader. Also have soft cab, rear chains, ROP not installed with mounting brackets,shed kept, battery.
Couldn't figure out how to edit. The tractor also has fluid in rear tires. Battery was replaced 9/14/2025
/ 1979 ford 3600 worth #3
I'll throw a guess out, low end, $3500; high end $5250. I would probably target arout $5000 asking, and take $4500; unless its in just amazing shape. If really nice, I could see as high as $7200. I dont think the soft cab ads any value. Loader does certainly add value, but I have a hard time, even pristine, seeing about $7500.
/ 1979 ford 3600 worth #4
BTW, if its yellow vs blue; I would honestly expect about $500 less.
I'll try to post some next week. If I can figure out how to post them.
/ 1979 ford 3600 worth #8
Assuming you're using tapatalk app on your phone, and the pics are on same phone, there is a square "Plus" under the text of your post and it says Photos, Files. Click that and select the picture from your device.
Okay thanks, I only have one picture of the tractor on my phone. Its more the sickle bar i converted to Hydraulic lift. But will try to post that one. Will take more next week when I am off. Wish me Luck. The tractor 78 Ford truck metallic blue and white
Found two more that I had on my phone
/ 1979 ford 3600 worth #11
Ok, I will revise my estimate a bit; if I was posting this for sale, I would probably go ahead and list it at $6000. Now, I certainly would expect to get a bit less, but it is a good looking tractor. All depends on how quickly you want/need to sell. Another thought, im assuming it costs nothing to own it, so, if your not getting bites at $4000+, maybe just keep it?
Thanks, I try to take care of my equipment. It needs a bath and waxed. Probably will do that this week after I service it. I don't need to sell it. I usually use one of the cab tractors now. But still run it about once a month. Spent a lot of time on it growing up. Just started thinking it's to nice of a tractor to just let it sit. Maybe someone could get better use out of it. But would have to go to someone that would keep in under roof when not in use. Still on the fence if I will sell it or not. Definitely not going to give it away. Going to have someone from new Holland come look at it. Maybe they know what I should ask for it if I decide to sell. I will post more pictures after I clean it up. Just has dust on it from sitting in the equipment shed. Thanks again for your replies.
/ 1979 ford 3600 worth #13
So, on servicing... You will not make more based on a service. Think about it from buyers side. You just bought a good looking, running, 40 year old tractor. Sure, the guy you bought it from "says" he did a full service; you, me, or almost anyone is going to do a Full service anyways, so we have a base line. With that, a "full service" I mean hydralic fluid, oil, filters, and possibly coolant. At times, you might even be suspicious, "Why did this guy just change everything, is it cause there is a problem, like water in oil, or something".
Now, if it needs an oil change, thats different, but I wouldn't really want to see brand new oil when I check it, as a buyer
Not doing the hydraulic system. Just engine oil and filter. Fuel filter. Change them every year. We service and clean all are tractors and hay equipment. Take the tension off the belts on the round baler. Things like that. But see what your saying.
/ 1979 ford 3600 worth #17
The blue and white Fords are popular in Virginia, and your 3600 has been well-kept. The smaller Thousand Series Fords are great utility tractors in my view. I would take lots of photos from all angles and maybe post them on Craigslist/Facebook Marketplace/? with a $6,000 asking price.
Personally, I would hold on to it, but I am admittedly biased towards this series of Fords.
/ 1979 ford 3600 worth #18
I know I would love to own it, it's about time to upgrade the 2N! That being said, tractors around here are listed at the high end of what i'd consider fair. Especially fords and JDs. So I could see $7k asking and settle a bit less. Then there's the guy who thinks he has the last tractor on earth and wants 10k-12k.
I agree to just do the oil change if it needs it, but leave everything else. When I'm eyeing up a new purchase, clean freshly serviced is a red flag. I want to see the old fluids, smell the oil for coolant or gas, see the even later of dust so I can see that there are no leaks etc. the dirt paints a picture on how it was used. If it's completely caked in mud then I know it wasn't really taken care of, but a nice even later of dust tells me you do wash it, no blobs of grease, no leaks on wheel bearings, brake parts, hydraulics, etc., just in the usual spots like on rear remotes, or loader pins etc.
/ 1979 ford 3600 worth #19
That tractor is worth what you paid for it new.
They hold value, especially one in good shape like yours.
Put your $$ on it and advertise it. Someone is looking for one!
