Rear Blade Rear Blade keeps breaking
/ Rear Blade keeps breaking #1
SOS
Fredericksburg, VA
NH 45 A (2006)
Question: Why does my rear blade keep breaking off the swivel?
I have a 45 hp tractor pulling 5 foot swivel blade and every two years the weld breaks. Is it that I need a heavy duty blade, is my tractor too big for the blade, or is this just a fact of life? I grade some ditches, dirt paths and sometime hit some roots that stop me.
What do you suggest and what is a recommended brand?
:confused:
/ Rear Blade keeps breaking #2
i have a 5 foot rhino tilt swivel and about every 2 years I have to replace the bolts. the heads pop off. Know I know mine is caused by catching it on a root or rock that stops the tractor, if I am going slow.
/ Rear Blade keeps breaking #3
I would say that your blade is way to small for your tractor. Usually for your size machine I would use a 7 footer that is at least medium duty. Land Pride or Woods make good implements. There are others also, but those two are the first that come to mind. Land Pride shows a weight rating for their blades, that should help you.
/ Rear Blade keeps breaking #4
i have a woods 6ft blade on my L4400, and it will stop the tractor, 4x4, with chains dead in its tracks, without breaking, though the moldboard willbend quite a bit, but it returns to normals
/ Rear Blade keeps breaking #5
better to break the blade than the tractor ...I have equivalent horsepower and run an 8 footer ...but it has hydraulic angle with a "cushion" valve to, well, cushion the blade and the tractor...
Thanks all. I looked mine up on the web and it was a Woods standard duty rated for 40 hp. So I guess I need to go up to a medium or heavy duty 6 or 7 footer. Any pros or concerns on these choices?
King kutter HD-RB 84
landpride rb35
rhino 300 or 350
Woods HBL medium duty
Any other choices?
/ Rear Blade keeps breaking #7
I'm partial to Land Pride, and I would go with a blade that will cover your tracks when at a 45 degree angle. (7 footer) But you definitely need at the minimum, a medium duty blade. If you have rear remotes, maybe think about getting a blade with hydraulics, they sure are nice to have. :D
/ Rear Blade keeps breaking #8
I had the same problem with a 6' Howse I used behind my Jinma 254 with R1's. My Ford 861 has no problem with this blade but the Jinma is just too much for it. My Jinma is heavy, 5,200#, and I could brake the blade at will. I busted it 2 times just pushing snow in the same fashion as you. I went with a 7' HD Woods and have not had a single problem.
Chris
/ Rear Blade keeps breaking #9
I had a KK from Tractor Supply that was fine for my TC29 when I owned it but I turned the blade into a U shape with my L4200, The light duty blades are not made for the bigger machines.
/ Rear Blade keeps breaking #10
I used to have a TSC blade on a Kubota M4700 (45 hp). I was a frequent customer at the local weld shop :( Later, TSC started rating their stuff for 30 or 35 hp max.
I upgraded to a Woods medium duty blade (MD72) and have not had any more problems in ten years, even though the current tractor is a bit more capable (M5040, 4wd).
/ Rear Blade keeps breaking #11
I use Woods B72 rear blade on L2800..beefy attachment for our nickname granite state..works great,and adjustment stand/leg comes in handy when attaching or unattaching...and
/ Rear Blade keeps breaking #12
I agree. Landpride stuff is pretty heavy built.
/ Rear Blade keeps breaking #14
I have a Ford rear blade #19 344 6' blade that is no means light duty. When I broke my pin off, I drilled all the way thru it and put a larger 1 1/2" pin in it's place. That puts the pin weld on top of the stationary part away from where the blade is trying to swivel. The pin you are breaking is probably being screwed up by where the weld is, and if anyone is trying to cool it with water after the weld, which will make it brittle.
/ Rear Blade keeps breaking #15
Now it makes sense to me that TSC rates their implimants for 35HP, I also ripped one of the ripper teeth on my KK box blade right thru the steel channel it was mounted to, I still need to re enforce it, probably a winter project.
Yep, I'm seeing a big price gap from $400 to $500 standard duty to the medium and high at $900 to $1,200.:(
/ Rear Blade keeps breaking #18
Check around at auctions - the solid steel in the 1/2 heavy duty blades go for about $800 - if you can find them.
I've been looking around town and found a land pride for 949 and saw on the web a KK for about the same. Are these not Heavy Duty? I'd like to make sure before I spend that much. :confused:
Also, if you look at the one add, its a 2006 model so its been sitting out for a while.
Width(Blade) 84" Weight(Approximate) 484 lbs. Angle(Position)
9 Forward up to 60 degrees right or left
5 Reverse up to 60 degrees right or left Height(Blade) 17 1/
Thickness Cutting Edges1/2 x 6 Heat treated Replaceable & Reversible (Double bevel)
Tilt Range5 Positions up to 30 degrees right or left
/ Rear Blade keeps breaking #20
We have the 72" version of that blade that we use behind our Kubota L3830 and have had no problems with it. seems quite heavy.
Aaron Z
