Worklight wiring questions for you Electrical Gurus
   / Worklight wiring questions for you Electrical Gurus #21
Nice thread- very informative.
Some tractors (if you're lucky) come with lots of extra wiring for accessories & lights. I have some extra wires behind my cab. They're always hot when the key is "on". Then I have some extra wires under my rear fenders that make the continuity tester blink when the turn signals are "on".
I plan to use the "blinking" ones for a set of wide-set road flashers for when the wagon is in tow to the farm on the road so cars can see me better from behind.
I guess the constant hot wires behind the cab are for running lights or ????? :confused:
   / Worklight wiring questions for you Electrical Gurus #22
Thanks Kennyd, I have read many of your posts and earlier today even pulled up all of your threads as they always seemed interesting. I read about many of your projects already. Looks like you have done some intersting things!
Nice work on mounting the lights Bandit. I like how you put Caplugs in the ends of the tubing, and covers on the threads of your bolts to protect your head from cuts.
Are you going to put the wires in plastic loom? That would finish it off very nicely.
Here are a couple of older pics of the lights wire-loomed (before the FEL plow).
   / Worklight wiring questions for you Electrical Gurus #24
Conifer is a nice area Bandit. Are you ready for another winter? I hope you don't have to commute on 285 and can work from home or locally.
   / Worklight wiring questions for you Electrical Gurus #25
I skimmed thru the Posts and was trying find out the paticulars on the lights. I'm needing a new work light for the rear. I want something bullet proof as the fender vibrates pretty good where it mounts. Is there such a thing as LED work lights? If so what vender should I look for? bjr
   / Worklight wiring questions for you Electrical Gurus #26
Check NAPA auto parts. They have a nice selection at my local store for tractors & trucks. :)
   / Worklight wiring questions for you Electrical Gurus #27
Yes, LED lights are available. LED technology is really improving and it offers the advantage of longer life, lower amp, etc. Their brightness is much improved. I bought LED lights by Truck-Lite. I think Advance Auto, Truck Pro, and many retailers sell them. They are a little pricey, costing about $100 each. They make a trapezoidal spot that really projects, and a flood that is a broader, more diffuse light that would be a better rear work light. They are very well made with stainless steel hardware. I don't have the part # with me but if you can't find them, let me know and I can look them up.
I also have another really awesome LED flashlight made by Streamlight. It is very small, uses two 123 Lithium photo batteries, but has a larger than normal lense/reflector. Its is called a Super Tac. Man, is it bright. It projects a beam like a big spotlight, and has a 3 hour run time. I was bow hunting the other day and when it became dark, out of curiosity I turned it on and shined it around my stand which was in a large open kudzu patch. There were eyes shining all around as far as several hundred yards away. I decided to turn it off so a game warden would not think I was spotlighting. But it is a nice light if anyone needs a powerful compact light.
   / Worklight wiring questions for you Electrical Gurus #28
I didn't read every single post, so what I say may have already been covered.
1. A tractor is not a truck and I see no need to complicate a simple light wiring system by using relays.
A relay is no more than a remote switch that is subject to all the arcing and failures of a plain old toggle-switch.
I would run the power, fused of course, straight through a big toggle-switch, and on to the lights.
You want a switch that sounds like Matt Dillon cocking his .45 when you turn it ON/OFF.
A big toggle-switch will far outlast any relay.
2. I have gotten in the habit of putting those simple generic available everywhere two-wire pigtails on every 12-volt accessory I install, especially every light (not including markers).
Having a pigtail, instead of being hard-wired, it is a simple matter to un-plug the light and remove it for any servicing it may require.
3. Don't trust the tractor/vehicle frame as your only GROUNDing point.
Go ahead and GROUND to the frame via any mounting bolts/screws; but, also, run a seperate GROUND wire, from the bulb itself, directly back to a dedicated terminal bar that is directly connected to battery-negative; this one policy will eliminate 99% of all light troubles.:cool:
We moved up here a little over 2 years ago from Boulder County. Love it up here. We're actually much closer to metro Denver now than before.
Unfortunately, I may be having to commute all the way to Boulder starting in a couple of months. Not really looking forward to that. And though I used to be able to telecommute when the weather was bad, it doesn't look like that is going to be a possibility with this latest opportunity.
But I am thankful to have a chance to bring in money in this economy. Too many folks out there can't say the same.
   / Worklight wiring questions for you Electrical Gurus #30
Bear
I've some maintenance background on my resume and I agree a hundred percent about the relays. They tend to get overused. They do have their application. I'm so over the hill now that the LED stuff is after my time, so I'm tryin to learn 'bout this new stuff. Is there a special flasher for the LED stop turn signals for low amp draw? I was thinking of mounting a set of LED stop turn on my Jinma JM354, but propbably would need the whole nine yards, you know turn signal switch and flasher unit to get the brake switch to work with turn signals. I do go down the road once in while and it would be nice to have the legal contraptions. bjr
2018 Deere 323E (A53317)
2018 Deere 323E...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
