TC34DA dead
/ TC34DA dead
Check the fuses under the hood on the forewall. On mine fuse#2 will disable starting if it blows. Not sure how different the 35 is from the 33 since it is the next frame size up.
Fuses are all good. 40amp on the starter, all on the right side fire wall.
Funny thing If I engage the E back lock, I get a rhymical click like the warning horn is trying to sound. doesnt stop.
/ TC34DA dead #12
My gauges and all are NOT working. I have no schematic to work from so I am just looking for obvious thing to try. If it is not battery cables where do I go from there?
I will try Battery cables tonight after work.
There may be some slight variation but this should be very close to your 34D, this is for a 33D:
  • TC Series Deluxe Electrical Schematic.pdf
/ TC34DA dead
thanks gives me a little more idea of what I am looking at.
/ TC34DA dead
Update,
Tractor is fixed and running. Several issues.
1) Bad Negative wire from battery to frame. Fixed? nope.
2) Bad positive wire from battery to starter/alternator. Fixed? almost....
3) Key switch faulty.... R&Rd tractor works well again.
Corrosion on the main power to the starter flanged nut showed bunt/arcing and melted a portion of the flange. Cleaned up the starter bold and applied protective coating. Corrosion in the positive wire to the starter... wires pulled out of the crimp connection, very corroded. Battery negative wire I cut open to find a lot of corrosion within the wire.... so bad it broke most of the continuity to ground.
Lot of headaches fixed all at once. Thanks to all who had a hand in helping.
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2019 John Deere R-4038 (A61307)
2019 John Deere...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
