Another work light question
/ Another work light question #1
captjack
Eastern Shore,MD
jd 5400
i put this in the Kubota section but It might be better posted here :
I built a canopy for my L235 and want to add 4 work lights. In the front I am looking at 55w 3X5 with trapezoid beams and in the rear I am adding the 5 inch round flood lights.
My question is - how much can the stock alternator/ generator handle? I do not think I would run all at the same time. The head lights are installed but not hooked up because they are worthless with the FEL installed.
Any thoughts ? Does anyone have pictures of canopy's with lights installed ?
/ Another work light question #2
Check
http://www.tractorbynet.com/forums/customization/139795-led-work-lights.html
and go LED.
/ Another work light question #3
if you find you can't handle four, consider the fact that you are (usually) either going forward or backward ...if you switch them differently you might consider a forward and a rearward on one switch and then the other two switched independently (3 switches) or switch each independently (4 switches) and manage the load yourself. The switches are quite a bit cheaper than installing a larger alternator.
KBH Tender Trailer (A61307)
KBH Tender Trailer...
Mini backhoe attachment (A61567)
Mini backhoe...
2020 MACK GR64FT DAYCAB (A60736)
2020 MACK GR64FT...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
