Air Filter Change
/ Air Filter Change #1
duckhunt
Central, Louisiana
Kubota L4240HSTC
How often to you guys change your air filter. It got pretty dusty this summer when we cleared out some land. I used my tractor 15 hours or so in some real dusty areas. My dealer said just shake it out now and then. I took a look at it yesterday, bumped it a few times, cleaned out the trap in the bottom. Do I need to consider getting a new one. It was pretty nasty and the trap was 1/4 full. Let me know some opinions.
Thanks,
Jonathan
/ Air Filter Change #2
Do you have a filter change indicator? If so that will give you an idea. Otherwise if you've only ran the machine for 15hours unless your in a volcanic ash storm or something as bad I doubt your ready to change filter. Like your dealer suggested tap the loose dirt out, clean your trap and drive on. Use your manuals suggested scheduled maintainence for when to change filter.
/ Air Filter Change
I dont have a filter change indicator.
It wasnt quite volcanic ash, but it as tough.:eek: Made wish for a cab. I figured it ok, just wanted a second opinion.
Thanks for the reply.
/ Air Filter Change #4
some tractors have a vacume indicator on the air filter housing.. keep an eye on it.
My unit has an outter an inner filter.. manual says to change the outter as needed and inner every 2ys as needed.. since I love my engine.. I change the inner every year, same as the outter.. though I do check the sediment trap, and will blow the outter out if it needs it, inbetween service.
soundguy
Thanks,
Jonathan
/ Air Filter Change #5
I think it really depends on hours of use and conditions. If you are running the tractor for example for snow removal in the winter your air filter should last a LONG time. But if you are doing a lot of dirt work in dry summer conditions it may need changing much sooner.
I would go by the owners manual.
/ Air Filter Change #6
A very dirty air filter will make your tractor use more oil, so if you notice the oil level dropping you should change it.
/ Air Filter Change #7
The air filter on my tractor is washable and per the manual, it can be washed in warm soapy water up to 6 times in its life. Manual says to change every 2 years but I change mine every year just because.
/ Air Filter Change #8
Hi Jonathan,
I do like most guys when my air filter gets clogged up ... shake it out and blow it clean.
I usually do it regularly especially if I've been working in very dusty dirt work or when brush hogging. You can tell when your temperature gauge starts to climb that your air filter might be plugged.
I added a "Filter Minder" that reads when the filter starts to clog up. It works on a vacuum basis and is very easy to install. I just added one to my wife's tractor in this thread. It's the very first post in it along with some photos.
New Mods to Loretta's 284 Jinma
You can get them online or eBay.
Rob-
/ Air Filter Change #9
Rob
How did you size the guage for Loretta's tractor? I see these guages come in 25 and 30 lb and cannot find how to properly size.
/ Air Filter Change #10
I didn't know how to size it either.
I bought the 25 lb figuring it would be more sensitive. When the gauge starts to show some filter clogging, I check and clean the filter. I use it as an indicator and don't wait for the gauge to "fill up" to max.
/ Air Filter Change #11
The inner and outer air filter separately serves its own functions. The outer filter stops the larger particles from entering the engine, and the inner filter stops the smaller dust/sand like materials. Its these dust/sand particles, much not visible to the naked eye, that has the potential to cause premature piston ring and cylinder damage. Its like running a piece of sand paper up and down the cylinder.
Usually air filters are changed on a time scale (e.g every 500 or 1000 hrs) or per milege of the machine. Provided that no excessive driving has been done, once per year at a minimum may suffice as a proper preventative maintenance schedule.
regards
M Khan
Ford Tractor Parts
/ Air Filter Change #12
The following was taken from a study about the effect intake airfilter condition has on vehicle fuel economy
(See page 16)
"A factory OEM indicator was taken from a 2001 Chevrolet Silverado with 5.3L V8 and tested to find the
Outlet DP (pressure differential) required to set the indicator or move the yellow indicator into the red zone. Using a vacuum pump and water manometer to test the indicator, the authors determined that an Outlet
DP of about 5.7 kPa was needed to set the indicator to the level corresponding to a clogged air filter.
Other air filter indicators from diesel applications were also tested. Both of the other two air filter
indicators tested were factory equipment for Dodge Ram pickup trucks with 5.9L diesel engines. One was
purchased new from the Chrysler dealer and the other was taken from a 2006 Dodge Ram pickup
equipped with a 5.9L diesel engine. Using the same vacuum pump and water manometer, the authors found that the vacuum needed to set these indicators was slightly less than that required by the indicator
taken from the gasoline application. These air filter indicators only required about 4.2 kPa to move the
It is common for air filter service indicators to be set between about 5.0 and 7.0 kPa."
4.2 kPa = 0.609 psi = 16.861 inches of water column.
5.7 kPa = 0.827 psi = 22.883 inches of water column.
pressure-units-conversion calculator
There's some good information in that study related to air filters and restriction levels but the one thing we can get from it, at least, is what the car manufactures consider to be the maximum restriction that an air filter should have.
The study also says:
"It is common, however, for servicing to occur when the filter appears dirty. Engine air filters are designed to actually increase their efficiency by using this initial layer of dust as an added filter layer. Initial filter efficiency is usually approximately 98% but increases to more than 99% by the end of the service life of the filter. Therefore, changing an air filter before the useful service life is
achieved can result in premature engine wear."
This mirrors what others has often said- that a slightly dirty filter actually filters better than a brand new one.
/ Air Filter Change #13
I once too wondered 'when' to change the air filter. I do it as needed. I have operated in total dust out conditions where I have had to stop to make sure I was still on coarse. Be it skidd'n logs with the 648 G-III, harrow'n or packing with the 790. In those conditions, outter filters get "knocked" clean daily and replaced after 40 hours of that harsh of service. Oil use has been a reliable indicator for me on air filter needs cleaned or time for new one after many cleanings.:rolleyes: Small time window, or good weather you Gotta go, and go hard when you can.... Engine temp on the 648 is another indicator of air filter ailment too.
/ Air Filter Change #14
Just bought a new air filter for my Kubota. Now that I've seen how much they cost, I might have changed my opinion upwards a bit about the time between changes.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
