Soon 2 buy first tractor; likely the BX1860 or BX2360
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #1
Mr. Ace
Member
MI
Kubota B2320
Greetings. First post - excellent forums here; I have learned a ton already. I will soon be buying a new Kubota tractor, my first ever tractor, and am hoping to mine some expertise from those who have been through the process. Until a few days ago, my knowledge of tractors was near zero.
I need a tractor for the nearly sole purpose of snow removal. I have a place in the snowbelt of northern MI with 1/2 mile of driveway/private road to clear. I believe a Kubota compact with the front blower attachment will suit my purposes, and the Kubota 0% financing offer is nice. I have it narrowed down to the BX1860 or BX2360, but will probably end up going with the 2360, as there is not a great price diff. If I can scrape up the coin, I would like to get the Curtis hard cab too, as the dealer will install for free.
My likely configuration for the 2360 (or 1860) is: bar tires, front snowblower (with hydraulic chute rotator & electric chute deflector), quick hitch sub frame, mid PTO. If I get the Curtis hard cab, I would get the usual options like heater, defrost, wipers, etc. I am also considering a rear blade.
I would be grateful for any suggestions/advice regarding my prospective purchase; such as; what "throw-ins" should I try for (service or otherwise), options, things I should look our for, etc. Also what percentage less than MSRP (retail) should I be able to negotiate in the Kubota world?
Thanks!
-Ace
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #2
That would be a 50" blower, so you may be making 2 trips out and back to widen out the drive.
Other than that, excellent choice. I have a 2200 and 2660 with front blowers on each.
If you are not mowing, a hard cab is also great for winter use. Not something you would take on and off, though.
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #3
choice. I have a 2200 and 2660 on each.
*If you are not mowing, a hard cab is also great for winter use. Not something you would take on and off, though.
I'd think when mowing a cab with air would be very nice.
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #4
Nobody said mowing- Just snow clearing. I would Definatly like a cab for that. Either tractor would be good for this. Personally I would like the tractor with the larger tires.
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #5
I have the hydraulic rotation which is awesome. I didn't opt for the electric deflector because I never need to move it when clearing snow. I only occasionally set it before getting started based on the wind and snow consistency. Drift knives are nice to have but my blower doesn't have any factory holes for them.
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #6
That rear blade option is a good one. It'll give you some ballast and come in real handy for those first heavy wet snows that clog up the blower chute.
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #7
I have a BX2350 and a 1/2 mile road that I have plowed with a Back blade. It works fine but if mowing is not in the cards, I would step up to the "B" series to get the 3 range hydro, higher top speed, more ground clearance and bigger tires. With a front blower, I would add a nice back blade. You could run the blower and the back blade at the same time for an awesome combo. Not saying a BX won't do it because I have, but the "B" will do that job better. My .02.
Excellent suggestions, thanks. I think I will forgo the electric chute deflector on the blower; that will save me $500. My first thought about upgrading to the B series, was that it would surely be nice, but way out of my budget. But, I might be able to pull it off, if I nix the hard cab. If I get the B2320 without the hard cab, it would be less than the BX2360 equipped with the hard cab. I would still eventually add the cab in a year or two. I'm seriously going to consider that.
I have a BX2350 and a 1/2 mile road that I have plowed with a Back blade. It works fine but if mowing is not in the cards, I would step up to the "B" series to get the 3 range hydro, higher top speed, more ground clearance and bigger tires......
Correct, I won't be using it for mowing, at least not in the forseeable future. Nevertheless, you can still install a mower onto the "B" series tractors can't you?
   / Soon 2 buy first tractor; likely the BX1860 or BX2360 #10
Depending on the model of the B-series they will take a 60 or 72" deck.
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
CATERPILLAR 308D CR EXCAVATOR (A59823)
CATERPILLAR 308D...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
