Has anyone ever had this break?
/ Has anyone ever had this break? #1
KenGod
PA
CK2610HST
working on my pond project this morning, I was pushing dirt mounds around with my 2375 bh, all of a sudden I heard a LOAD SNAP and the bh was floppy, I took a look and almost pooped myself. I have a call into the dealer, still have 2 years left on my warranty, hopefully it will be covered, looks expensive, looks like my pond project is on hold till its fixed.
If I had to guess the lower arm pin came out and when I moved the bh left/right it snapped the hydro arm
My dealer (Hoover Tractor) just called me back, they will pick the tractor up on Monday, fix it and have it back by Wednesday. :D
Love my dealer, but I dont know what to do with my weekend now that I cant dig my pond.
o well there is always next weekend, guess I will have to go and mow the grass
/ Has anyone ever had this break? #4
That's great service and they seemed to be right on top and prepared for it. Wonder how often they have seen that type of break on thise BH's?
/ Has anyone ever had this break? #5
Dealer service sounds great. When you say "pushing dirt mounds around with my 2375 bh" if you mean using the side swing and the side of the bucket to grade, that puts a lot of force on that pin and swing cylinder. We all do it to some degree but at least my manual does not recommend it.
MarkV
/ Has anyone ever had this break? #7
Yes had a customer break one on a Kubota and I broke one on my JD 510 .
/ Has anyone ever had this break? #8
Wow! Even I couldn't manage to do that! :D Good thing you were not handling something delicate, or working with helpers!
Isn't there a grease fitting for that pin? :confused: It's dry as a bone. The wear is significant, and all of the other pins appear to be well greased. I would call that a design flaw, and would have a greasable pin installed.....
Tractor will be back home tomorrow am, I asked the service mgr what he did, He told me that they weld the cylinder end back together, At first I wasnt sure if I liked that, he went on telling me they rebuild hydro on a regular basis, when they get the chrome portion of the hydro cyl it does not come with the end on it, they weld the proper type of end on it for a specific application. He said kioti would send a hole new assemble bu he guaranteed me that the welded tip is at least as strong as factory.
Well looks like it will be back to my pond project this weekend
/ Has anyone ever had this break? #10
Seems to happen often and not to just 1 type{make or model}.
/ Has anyone ever had this break? #11
AS long as that boom pin is lubricated and fastened, I can not imagine how that cyl. would snap. There are hoes with literally thousands of hours on them, tons of abuse, sloppy pins, the whole nine yards and a cyl like that would not snap.
You are obviously correct, pin fell out, everything miss aligned and cyl. snapped.
Pin should not have fallen out in the first place.
Good reminder for all of us to be sure to check everything possible for tightness and lubrication.
Joel
/ Has anyone ever had this break? #13
When you swing, does the cylinder shaft pass over the pivot pin? I'd suspect the pin worked up, you swung and cylinder hit pin, snapping the high carbon steel rod.
Good reason for a thorough inspection before each operating session.
As for the welding, there's no reason it won't hold as long as it was welded with a buzz box and not a mig...... Hee hee hee!!!!
/ Has anyone ever had this break? #14
Did your dealer charge you for pickup and delivery?
NO charge, they never do. I live about 5 miles from the dealer, another reason why Hoover Tractor is awesome.
/ Has anyone ever had this break? #16
Good point, had not thought that through. One thing with strong metal pieces, they are super tough when lined up correctly, get something out of line and man they can look auful weak super fast.
Joel
/ Has anyone ever had this break? #17
the other cyl you install will break to if you dont fix the worn pin in the center section it puts the cyl in a bind just my thoughts good luck
they replaced the lower pin, seems to be working fine so far
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
Pat's QH and hydraulic top-link.
Pat's QH and...
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
