Has anyone ever had this break?
   / Has anyone ever had this break? #11
AS long as that boom pin is lubricated and fastened, I can not imagine how that cyl. would snap. There are hoes with literally thousands of hours on them, tons of abuse, sloppy pins, the whole nine yards and a cyl like that would not snap.
You are obviously correct, pin fell out, everything miss aligned and cyl. snapped.
Pin should not have fallen out in the first place.
Good reminder for all of us to be sure to check everything possible for tightness and lubrication.
Joel
   / Has anyone ever had this break? #13
When you swing, does the cylinder shaft pass over the pivot pin? I'd suspect the pin worked up, you swung and cylinder hit pin, snapping the high carbon steel rod.
Good reason for a thorough inspection before each operating session.
As for the welding, there's no reason it won't hold as long as it was welded with a buzz box and not a mig...... Hee hee hee!!!!
   / Has anyone ever had this break? #14
My dealer (Hoover Tractor) just called me back, they will pick the tractor up on Monday, fix it and have it back by Wednesday. :D
Love my dealer, but I dont know what to do with my weekend now that I cant dig my pond.
o well there is always next weekend, guess I will have to go and mow the grass
Did your dealer charge you for pickup and delivery?
NO charge, they never do. I live about 5 miles from the dealer, another reason why Hoover Tractor is awesome.
   / Has anyone ever had this break? #16
Good point, had not thought that through. One thing with strong metal pieces, they are super tough when lined up correctly, get something out of line and man they can look auful weak super fast.
Joel
   / Has anyone ever had this break? #17
the other cyl you install will break to if you dont fix the worn pin in the center section it puts the cyl in a bind just my thoughts good luck
they replaced the lower pin, seems to be working fine so far
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2022 CAT skid steer (A55973)
2022 CAT skid...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
14C SCRAPER (A58214)
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
