BX23 Toothbar
   / BX23 Toothbar #21
I too have a markham toothbar.......... I drilled in middle of slot. It only takes two minutes to unbolt, so I keep two wrenches in the toolbox with tractor and if my project all of a sudden requires a smooth bucket, I tilt bucket quickly unbolt let it drop off with a tap of hammer and then reinstall later if so needed.
Love my toothbar for clay work or even for scoring thick ice on the gravel driveway in spring thaw.
jake
   / BX23 Toothbar #22
Markham toothbar teeth extend below edge of bucket. They are very effective for breaking into sod or dirt. Because they dont provide a flat surface, backdragging is done with heel of bucket to get teeth out of way. So.. the position of slot should not be a worry.
One thing to watch out for is the extended reach of the teeth. Most of the time they are out of your line of sight and have they annoying habit of catching on things while turning if you let your guard down for a second. Did some damage to my garage door trim in one of those moments.
They are a great help in getting the job done. Good luck and watch out with those teeth.
   / BX23 Toothbar
I thought about exactly that. These teeth could put a real hurtin' on stuff.
I'll have to go practice somewhere before I de-sod the flower bed sites. I've only used a toothbar on a skidloader, you can see what you're doing on those, kinda blind on this.
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
