BX23 Toothbar
   / BX23 Toothbar #11
timswi,
I have a Markham bar on my BX 23. I love the bar, but I had to do a little grinding to get it to fit the inside of my bucket. I did measure the inside of the bucket, and provided that to them; I'm not sure why it didn't fit right out of the box...
To be fair, I did not call Markham to get it rectified. I just commenced grinding. Maybe they would have sent me a different bar that fit better; I never gave them the chance. I needed the bar that weekend, and was unwilling to wait.
Also, when you get a bar, contact me. I'll give you a pointer or two on how to mount it, based on my mistakes...
Having said all that, I love the toothbar. The tractor will bend before the bar does, for sure...
Pat
   / BX23 Toothbar #12
Search the 2 Kubota forums for "BX" together with "toothbar". You will find many hundreds of posts on this in the archives. It has been discussed to death.
My Markham for BX2200 was only $150and I love it. Markham will give you the best customer svc. that you could ever imagine.
   / BX23 Toothbar
timswi,
Pat
Thanks for that Rip...I'm sure I'll get back to you once I get the prices...I'm like you, I cant tell you what to do, but I can certainly tell you what not to do.-
   / BX23 Toothbar
I bought a BX2350 a year ago. Last fall I ordered a tooth bar from Markham Welding. There have been any number of threads on TBN on tooth bars (in general) and Markham (in particular).
Markham asks for one measurement. They then send you a tooth bar made to fit your particular loader. Simple. Mine is so over-built something else will give before the tooth bar will. I am more than satisfied.
Doug
BX2350, fel/w Markham tooth bar, and more stuff.
Thanks guys. Contacted Markham, very responsive and a very fair price.
All kinds of stuff just broke around the house. So once I recover from all of that, I'm going to order one from them.
   / BX23 Toothbar #15
BTW drill the holes in the loader in the front of the slot so you can loosen bolt and pull forward and flip in to bucket for flat edge.
tom
   / BX23 Toothbar
tom
Thanks for that info...I probably would have just drilled it, then smacked myself upside the head!
   / BX23 Toothbar
timswi,
Pat
Ok Pat, the toothbar showed up today...Holy cow! It looks well made.
What tips do you have before I start drilling like a knuckle dragging neanderthal.
As Tom had said, the bolts would be better in the front of the slot to allow it to be flipped into the bucket for smooth back dragging. Does that cause the bar to get loose though?
Anybody have any pictures of theirs?
I'll wait for opinions...Thanks
   / BX23 Toothbar #18
And in case you've not come across it, there's a selection of several with photos and links on the BX Wiki.
The Markham tooth bar on the BX WIKI section is mine...:D
I didn't care about flipping the tooth bar up...when I don't want to use it I'll simply remove it.
   / BX23 Toothbar #19
tommu56 nailed what I was going to recommend. I didn't think about flipping it up before I drilled the holes in the bucket, so I drilled the holes at the back of the slot, thinking the bar needed to be on tight...
In hindsight, I haven't really found myself needing to flip it up, but I hate locking myself out of options because I was dumb...
When you are driving forward, the side bolts probably serve no real purpose, as the toothbar slips over the leading edge of the bucket. But if you backdrag at all, or rake backwards, as I sometimes do when clearing brush, I would think those bolts would have to be pretty snug, so maybe having them at the back of the slot prevents the bar from being pulled off the bucket edge.
Does that make sense what I'm saying?
Let me know how it fit out of the box, out of curiosity...
Pat
   / BX23 Toothbar
Pat
That was my thought on the bolts. Mine is 1/2 inch narrower than the ID of the bucket. I thought that it was supposed to be 1/4 shorter. Need to make up a pretty big gap. Dont want to stress anything, bending or cracking the bucket..If I use washers, that will stress the bolts, unless there isn't any stress on them..Can't tell yet.
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 Chevrolet Express 2500 Cargo Van (A50323)
2017 Chevrolet...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
