Farmwithjunk
Super Member
That is good news but the real question is .......did he pay your bill for work done?
Yes. Before I was even done.....Go figure
For issues like this I wonder if a person had a form that the property owner would sign that are no obstacles (to protect the contractor) or utility or septic lines ( I'm sure that one could make it more generic) that could be damaged on the property while doing the requested contract for services. Once signed it should be the property owners responsibility. I'm no expert but it seems as if there should be some method to protect the contractor on an issue such as this.![]()
Seems the wisdom in this is often overlookedA lean compromise is better than a fat lawsuit.
George Herbert
they can still sue you right thru that lil piece of paper contract... once in court it might hold some water.. but you have to jump thru all the hoop$$ first..
soundguy
Now, who wants to go mow someone's weeds for a few extra bucks?
Ah, but they don't. I've had two threats, and both times I pointed to the contract and the problem went away. Once was for a cracked driveway, once was for a cracked driveway (apparently a half-ton full of lumber was too much for it) and once was for a underground lawn watering system in a yard I couldn't have hurt.
There have been legitimate things over the years, and I gladly fix them, no matter what the contract says. Word of mouth advertising is worth more than a few bucks.
soundguy
