JD 4230 overhaul
/ JD 4230 overhaul #1
5.9C
Hey new to the forum! I have a JD 4230 non-turbo diesel that is in need of an overhaul. Does anyone have any expeirence that they could share with me about this motor? Its a 73'. Thanks!
/ JD 4230 overhaul #2
It is typically cheaper to purchase a new engine or a rebuilt from a rebuild shop.
Does it need a full overhaul or just a bottom side?
/ JD 4230 overhaul #3
unless you need a block you should be able to get a inframe overhaul at the dealer for around $3k. i have had a 4440 jd overhauled at the jd dealer for less than 3 grand including machine work on the head. this was using oem parts & a 1 year unlimited hour warranty.this was done 4 or 5 years ago, so i know parts have gone up, but unless your block is damaged this would be your best way to go.
/ JD 4230 overhaul #4
JD engines are a wet sleeve design ? then you could easily pop them liners, pistons, rings yourself, and buy valve seating polish and a suction cup on a stick to do the heads.\
If the head gasket wasnt blown, sandpaper the surfaces clean, no need to skim.
Also, depending on the hours, you might want to inspect the crank bearings.
/ JD 4230 overhaul #5
In some cases, just not THIS case...... A "new" 404 Deere crate engine (Or better choice would be a 466, al la 4240) would cost considerably more than an in frame overhaul by the time you add in labor for a swap.
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2022 EZ-GO ELITE...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
