Tires wheels not tires, tires will come later
/ wheels not tires, tires will come later #1
bal0123
Purcell, Oklahoma the middle of no where
Yanmar 2210, and 2, 425 John deere lawn tractors
Hey yall, I have a yanmar 2210, it is a great little tractor, I have owned this tractor for about 7 years now and it is amazing what I can do with it. My question is about the wheels. I have 9.5 X 24 on the rear with a 6 lug bolt pattern and rice tires filled with 20 gals. of window washing fluid each tire. I am wanting a wider wheel like on the John Deeres for two reasons: a little more of a cushioned ride and to allow more window fluid than I have now for extra weight. I also would like to replace the front wheels with more of a automotive style tire. Between the Thistles, Goat-Heads, and Cactus thorns the stock bias ply tires always leak and nearly always have flats and I have had to replace them just about every 2 years cause of so many punctures. I think a radial tire will fix the problem for the front and hopefully the R4's for the rear. Do yall have any suggestions on where I can find some wider wheels for the front and rear. The front wheels are 4.0 X 15 - 4 lug. Any suggestions would be much apperciated. Thanks
/ wheels not tires, tires will come later #2
Yanmar also ran a 5:00x15 tire on that 3x15 front rim. 5:00x15 is available as an implement tire (5 rib) as well as 3-rib.
I have wondered about 5:50 x 15 auto tires (early VW and Volvo). I wonder if tougher trailer tires are available that narrow.
But as you noted you probably need wider rims to do it right. Then you might run an 8 ply trailer tire. However, steering it might get exciting. :)
/ wheels not tires, tires will come later #3
I have 7 x 15 Gm wheels on my YM 2500. I just cut out the old center and made a new one from 5/16 plate steel. Drilled new lug holes and center to fit the Yanmar. I'm running 8.5 x 15 8 ply trailer tires on the front
/ wheels not tires, tires will come later #4
I believe heywheel.com has been recommended before on this forum for a new set of wheels.
/ wheels not tires, tires will come later #5
I bought my wheels from Heywheel to put new R4's on. Good price, good service, truck shipped to dock near me. Terry
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
17101 (A55851)
17101 (A55851)
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2016 Ford Fusion AWD Sedan (A59231)
2016 Ford Fusion...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
