Which 3 pt. quick is better?
/ Which 3 pt. quick is better? #21
I was thinking about getting a quick hitch, but decided on getting a top n tilt. I already have the hydraulics plumbed for the 2 hookups when I bought the tractor. Yes it's probably double the quick hitch but it gives you so many more options for what I do. I't not just up and down it will angle and give you left and right when hooking up by shortening or lengthening the top link.
I also was looking at a quick hitch but with the acres we have the top n tilt seemed to address my needs better and I don't have to leave the seat when operating the equipment.
Check out ccm machinery. They are a member here.
Baranx, Top n Tilt is great, but I think your comparing two different concepts. A Quick Hitch is about connecting your Lower Links (and some with top links) to the 3PT Implement Faster. Like switching from a Brush Hog to Box Blade.
If I need to connect my Boxblade, I just back up, lift, and the bottom links are connected. 5 Seconds. With Top and Tilt alone you still need to get those lower links connected. How long does it take you to hook up? I know you don't have to leave the seat when operating the equipment with T & T, but were taking about changing/hooking up different equipment.
Many have T & T And Pat's Easy Change, Like 3RRL(Rob)
/ Which 3 pt. quick is better? #22
Well,
I really wanted Pat's but just could not afford it..
I bought this one off ebay for $65.
Skid Steer Attachments Pallet Forks Hay Spears Bobcat Cat John Deere Mount Plate
The only difference I see between it and PAt's is the self locking mechanism.
That would be nice, but I have really bent the fool out of my box blade..
So I need to get some new arms for it...
Most will work..
Just depends on your needs and the attachments..
As a side-- I did not have top link length issues..
Later,
J
/ Which 3 pt. quick is better? #23
...but I have really bent the fool out of my box blade...
...So I need to get some new arms for it...
Got my the BB 1 1/2 yrs ago for $488 (5' wide with 5 Scarifiers). Check out the Box Blade arms. Nothing there to bend! Pic was from when I got it new. Just want to let you know what's out there.
/ Which 3 pt. quick is better? #24
I like that one..
If it wasn't raining I'd go take a pic and show my destruction..
I paid $435 for mine.. and wish I had yours...
J
/ Which 3 pt. quick is better? #25
Yes you have to leave the seat, but you hook up much faster than te traditional method with little to no gruntwork. It takes the work our of needing a pry bar. Plus now you can operate it making adjustments on the fly.
Now how many times do you get off your tractor to properly adjust your boxblade when your top link isn't where you want it, or when your adjusting your plow.
/ Which 3 pt. quick is better? #26
...and I don't have to leave the seat when operating the equipment...
Yes you have to leave the seat, but you hook up much faster...
As I said before, seems like you're talking about two different concepts.
Operating the equipment and hooking/unhooking the equipment. I agree with you that T&T is great for operating. Just saying that a quick hitch is faster to attach/detach than without a quick hitch. And if you have both T &T and a quich Hitch, that would be the best of both worlds!
2008 Freightliner B2 Bus, VIN # 4UZABRDJ78CZ17948 (A61165)
2008 Freightliner...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
1000 Gallon PT Water Tank (A62177)
1000 Gallon PT...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2025 LandHonor HPF-11-3000G 48in Hydraulic Adjustable Forks and Frame Skid Steer Attachment (A60352)
2025 LandHonor...
2015 Dodge Grand Caravan Van (A61569)
2015 Dodge Grand...
