Box Scraper Box Blade Oops!
/ Box Blade Oops! #1
Bignoles
Member
Terrell, TX
International 784
Hello,
This is my first post, but I have been searching the site regularly for information since I have recently bought my first tractor (used).
The tractor is an 84' International 784, box blade is a 7' bush hog MBX840. Now to the problem, I was using the box blade yesterday, turned the corner around the gate (not very fast) and the outermost ripper shank ran into my back left tire causing about a 2' long gash/tear in the tire...not gonna be able to patch that, just glad it did not cause damage to the BB or 3PH. After much cussing I began to wonder if there was supposed to be something that keeps the box from swinging that far to the side. Am I missing something? I have not located a new/used tire yet but I'm guessing that an 18.4-30 ag tire is not too cheap! Any help would be appreciated.
/ Box Blade Oops! #2
There should be limiting chains going to the 2 lower 3 point lift arms connection to the tractors rear axle area near the rear tire.
Chris
/ Box Blade Oops! #3
could you patch the tire and then put a tube in it? The patch would not have to be air tight, just holds everything together and keep the dirt on the outside. And there should be check chains or possibly adjust your top link to get a better height/angle.
/ Box Blade Oops! #4
Hello,
First of all welcome.
Yes you should have side sway stabilizers to prevent that, usually they have a turn buckle to snug them up and keep things tight.
Here's some pics, see if these look like yours.
JB.
/ Box Blade Oops!
Patching the tire is out, the ripper tooth caught and ripped the tire about 2' around, looks like somebody unzipped the darn thing. I think I have a picture of the tire on my other computer. If so I'll put it on here as a what not to do with your new toys
First thing after putting a new tire on is going to be check chains, got it!
Thanks for the replies.
Nolan
/ Box Blade Oops!
JB4310
Thanks for the pics. No, I do not have the stabilizer you are showing. I have the lift arms, and the support rod? that goes up, but not the stabilizer with turnbuckle you have.
I'm guessing they do the same thing as check chains like has been said.
Thanks again
Nolan
/ Box Blade Oops! #7
Sorry about your mishap.Looks like some good advice already. Wish you better
luck.We all screw up.
/ Box Blade Oops! #8
Some have chains, some have turn buckles, some have sliding sway bars with holes for a stop pin. They are a must for just about all 3ph implements. Check with a dealer that knows your make tractor and get some before you tear anything else up.
/ Box Blade Oops! #11
Nolan
Put a new zipper in it.:D
/ Box Blade Oops!
Dang! Is that all you have to do is replace the zipper? What isle of the store are the tire zippers in? LOL I can imagine that conversation at wal-mart.
Destroying a tire is my limit on self-inflicted stupid for this week, but seriously how much should I expect to pay for a new tire and tube (18.4 x 30)
Thanks
Nolan
/ Box Blade Oops! #13
Ag tires are expensive....
Looks like $626.00
Edit - oh, that's just the tire, tube is another $60 or so.
--->Paul
/ Box Blade Oops! #15
Search around the net for the tire there are a few bargains to be had, Although they are expensive also. I found two that were right for me on on line auction site. But for the rears I actually found them locally for less.
You could possibly make your own sway chains with some chain and a few bolts...
/ Box Blade Oops!
Found the tire local for $495
I was looking at the tractor last night (still on blocks, tire will take a couple days to get in), need a couple pieces of chain from the garage, some repair links and BAM, I coulda saved a lot o money
/ Box Blade Oops! #17
Check around. There is usually a tire shop that looks really dirty and decrepid but dozens of cars coming and going. They are the ones that take care of their customers and usually have a wide assortment of orphan used tires. I have gotten some real deals that way.
/ Box Blade Oops! #19
Mr Brown, Could you make your replies a little bit smaller, and use the most opaque color you can find. I am going blind here, and you aren't helping any.
THANKS
/ Box Blade Oops! #20
One thing to watch for is to have thread wear as close to the other as possible. a new tire against a half worn out one, will cause the old tire to slip in rough going.:(
Tom in Vermont
