Oil & Fuel l3400 oil change
   / l3400 oil change #11
I change filter and oil at 50 hrs regardless. I'm only putting 50-60 hrs per year on my machine so that is a no brainer for me. Filter is easy to change while I am waiting for the oil to drain out and the cost is minimal.
Geez. I only have 36 hours on my machine in four years. I think I will change my oil this year because I will never get to 50 hrs. Brian
   / l3400 oil change #12
LOL! I'm not sure Brian. I think it might be time for you to trade up with that many hours on your rig.
   / l3400 oil change #13
The same thing happened to me. I drained 1/2 quart to bring the level to the correct level on the dip stick.
   / l3400 oil change #14
It seems stupid even to me but I was actually considering a similiar horsepower in the Grand L just for the stronger loader. I move both square and large round bales and it does not take very long and the hours not adding up.
Since shimming up my relief valve the weight is now not a problem.
Of course right now my local dealer sure has good pricing on the Grands but I would get killed on my L3400.
I think this Summer I will get some time on it. I felt pretty good when I got under the $1000.00 per hour mark in costs. Brian
   / l3400 oil change #15
Can't tell you how many times I've pondered a GL3240 or 3540 myself. I just can't get myself to do it though given the L3400 does everything I could ask of it.
Up here in Canada, you tend to lose a lot on transaction costs (sales taxes). Trade in prices I have been offered when I looked into it, were a joke
I figure at about 3 years and 150 hrs, it has depreciated about as much as it will . I'll probably get not much less than I would get for it today on the used market after another 5 years when it has 400 hrs on it.
Plus if I ever trade, the new tractor is going to have a CAB and probably a backhoe and all of that is going to add up and my wife is going to throw me out.
Are you moving those bales with the 3pt or a loader mounted spear? I was putting out a 5x6 round for the horses with the 3pt today and for the first time it grunted and i felt like it was at its limit. It did the job fine but I was wondering if I shouldn't shim as well. I imagine it will give me another 150 odd pounds at the 3pt.
   / l3400 oil change #16
On any of my equipment, I never trust the manual for exact capacities, I drain and fill to full line, run motor to fill filter then fill to full line and write it down either on hood, valve cover...etc
   / l3400 oil change #17
I use a bucket mounted bale spear. I welded a piece of 3x2 angle on the top edge of my bucket. I then bought a bale spear and made up a system to easily attach and remove it from my bucket. It works pretty slick. Brian
   / l3400 oil change #18
I second that!!
The manual I have says my fuel tank is supposed to be 9 gallons.
Well, the other day I ALMOST ran out of gas.
The Gauge said empty and I decided to just move it out of the garage before refueling it. For some reason I don't remember putting it up empty.
Anyway, once it was outside I decided to check just how low it really was.. and with a flashlight the bottom of a dry tank was plainly obvious..
When I refilled it, it took 1 full 5 gallon can and maybe 1/4 of another to fill to the middle of the neck on the tank when the cap fits.. Even if it was to the brim it would have only been another 4 onces!
So where in the world do they get 9 gallons?
I would say 6.5 maybe 7...
Could it really hold 2 to 2.5 gallons between the lines, filter and injector assembly?
whatcha think?
J
   / l3400 oil change #19
J
I think I should say full 5 gallon tank to the fill line.. not above it..
If it was totally full I could see it adding up to 9 gallons.
J
   / l3400 oil change #20
I've put 8 gallons :eek: in my L2800 once... not sure why the darn thing even HAS a fuel gauge... :mad: It will read empty after 4-5 gallons are used. If kuboota quality is this good, how bad are these other brands???
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
