FIRST Tractor- Kinda nervous!
/ FIRST Tractor- Kinda nervous! #1
Little John
Member
Wisconsin
Ok, I am buying a New Holland T2220 tractor(hydro-35hp.) with loader. I also added a 6' rear blade, 12" auger and 48" rotary cutter, all Rhino equipment.
I will be using the tractor for some snow removal, food plots, general work on 36 acres.
What pitfalls should I watch for?
Any Advice with the Hydro on hills or working with the equipment?
What are the most common newbie mistakes?
THANKS!
John.
/ FIRST Tractor- Kinda nervous! #2
Hi John and Congrat for your purchase (or upcomming purchase).
I have a removable back-hoe. Once, I removed it on a uneven ground and when it was time to put it back, I have to stop the tractor to disconnect/reconnect the hydro hoses and put it in neutral to start it back. It wasn't a steep hill, just uneven enough so the tractor started to slowly move on its own with only the hoses attached :eek:. Lucky enough, I was able to hold the tractor and quickly put it in gear to back it up a bit without breaking anything... (I guess this is a good advise for the loader as well!)
Lesson learn!!!
I'm far from being the most experienced person on a tractor but my better advise would be What ever you do, don't rush it, take your time and work it slowly...
Enjoy!
Max
/ FIRST Tractor- Kinda nervous! #3
THANKS!
John.
Nervous guy--congrats on your new tractor and implements.
With 35 hp and 36 acres I probably would have selected a 60" rotary cutter.
I only have 10 acres of flat pasture. Before I mowed it for the first time, I walked the property and found a lot of junk in the weeds that I wouldn't have wanted to run over with my brush hog rotary mower.
Careful with that FEL, especially in soft ground where the front wheels are making ruts. It's easy to get tipply with a load in the bucket when one of the front wheels drops into a rut.
If that NH has 4WD, be careful when using the FEL on concrete surfaces. The front wheels can sometimes stall when you push the bucket into a pile of something. If you're in 4WD when this happens, you coulld damage the drive train to the front wheels. Better to use 2WD in this case.
Some people consider the 3pt hitch-mounted auger (aka post hole digger, PHD) to be one of the most dangerous tractor implements. Be careful. And be sure you have your BF pipe wrench and a long cheater pipe to extract an auger that's jammed in a hole.
/ FIRST Tractor- Kinda nervous! #4
Keep the FEL bucket low when moving around. Seat belts and parking brakes are there for a reason. Lower FEL and 3ph when parked. And if you park it in the sun, flip the seat up so it does not heat up 160* when you sit back down :eek: Slow and careful, especially on hill sides. Any hills in Wisconsin? 4wd helps with braking on loose gravel or wet grass... I keep mine in 4wd most of the time and don't worry about any wear or tear. Only have to lose control once to learn that lesson.
/ FIRST Tractor- Kinda nervous! #5
If you don't have loaded tires, be careful with the FEL. Best to always have some kind of counter weight on back (like the cutter) when using the FEL.
/ FIRST Tractor- Kinda nervous! #6
Read the manuals until you understand them. Good to go over them while at the equipment so it helps make sense.
Keep you fingers in your pockets when hooking up equipment..since you can not do that be sure you know where each one is to prevent major pinch job.
Be sure when you have someone helping you hook or unhook, that both of you know exactly who is doing what, how and when. Do not stand between the equipment and tractor to hook or unhook. Dangerous area. Be sure to block the equipment before you unhook. Solid blocks of treated wood works good for this. Like 6 x6 or such. Don't forget to hook and unhook the PTO shaft and again be sure fingers nor any clothing near such when on.
You don't drive in idle. The trans needs rpms to pump the fluid.
Call before you dig if any kind of utility lines could be there.
Read through threads here and other sites will help you more than you think.
/ FIRST Tractor- Kinda nervous! #7
When using the implements around fencing go slow and watch when you turn.
It's amazing how much fence you can knock down with the loader and bushhog. :D
Have fun with your new tractor!
/ FIRST Tractor- Kinda nervous! #8
you might want to load the rear tires at least half way with the FEL. Read your owners manual inside and out, make notes in margin when needed, when using the tractor refer to the manual over and over again. Keep the rpms up when working 1800 rpm
/ FIRST Tractor- Kinda nervous! #9
Good Afternoon pitt_md,
Hmmm, was it the darn fence or the darn bushog ??? ;) I think I know what you mean ! :)
Ok, all good tips! My rear tires will be loaded w/washer fluid.
I figuered the auger would be a dangerous tool. But I am one of those guys that loves to plant trees. I'll go SLOW. Plus my soil is sandy loam, that should help a little.
My bucket is a 60" not the 68 that is normally put on. I wanted this for 2 reasons, 1) I dont have a lot of space in my barn and 2) I would be a little less likely to tip the dam thing over by over loading.
What RPM to use the rotary cutter? The auger? Also High, Med. or Low hydro select?
I only have about 1.5 acres of pasture that I cut once or twice a year and if I get it done too quick, I dont have enough beers!:p
I use my 54" Kubota GR2110 to mow my clover plots and lawn. Its an awesome machine.
"BF" pipe wrench? J/K...I know what you mean!
That would be VERY bad for me as my neighbors cows would get out!
Thanks for the tip!!!
OOPS forgot to mention, it is 4wd. I also have plenty of hills.
/ FIRST Tractor- Kinda nervous! #14
If you don't already have them, budget for the following. Wants grow up and become needs...
Trailer
Welder
Bigger Truck
Bigger Barn
Another Tractor
Bigger Trailer
Better Welder
And so on...
/ FIRST Tractor- Kinda nervous! #15
Little John - As for the RPM's for the auger, I would recommend just enough to keep the engine from stalling on the hole you are digging. My idle RPM's is around 1350 and I usually dig at 1500 RPM's or less. My Leinbach manual says to dig at "just above idle". You will be suprised at the digging power at low RPM's. Also, it's much safer to start your hole at low RPM's.
/ FIRST Tractor- Kinda nervous! #16
I was going to suggest going with a 6 ft mower myself. I think he has plenty enough tractor for it anyway, unless he got the 4ft on purpose. Like if wanted to get it in somewhat narrow spots, then I would have probably suggested the 5ft like you mentioned.
As for the auger, you will need to come up with a good way to park it when not using it. THat is the most unwieldy and aggravating implement you could ever buy to use on a three pt hitch. You might want to consider either suspending it from a handy treelimb, or put a couple of 4x4x10's in the ground and add a cross bar over the top to suspend the PHD from.
Like already mentioned, the PHD is one of the most dangerous implements. When using it, make sure no one is anywhere near it except to position it, then have them step back several yards before engaging it.
Since this is your first tractor, take it slow and easy at first and become very familiar with how EVERYTHING and EVERY PART of it works. Give yourself time to learn how it reacts to the different commands you give it. Become familiar with the turning radius with implements attached, note how far out they extend from the tractor front and back.
Wear safety glasses, good leather gloves, and ear plugs when needed. If you're cutting some real tall grassy/brushy areas for the first time, walk over them best you can before starting mowing to spot stumps, logs, stumpholes, scrap metal, or any IMMOVABLE objects!!! Nothing worse than one front tire slamming into a hidden stump and then having both front wheels make a hard turn at speed!
Always wear a cap or hat too. Helps some when/if you mow right on top of a hornet or yellow jacket nest!! You can at least use it to swat the buggers away from you some! LOL.
Keep your cell phone with you in your pocket in case something bad should happen. At least that might give you a fighting chance should the unthinkable happen.
Oh yeah, keep reading tractorbynet!!! There is a veritable wealth of wisdom and knowledge here!! And the pictures are pretty interesting too if you love tractors! Good luck and be safe with it.
/ FIRST Tractor- Kinda nervous! #17
I've heard/read that if you load tires to always load them about 3/4 way full so the rims are always covered with fluid. This helps reduce the chance of them being exposed to air which can accelerate rust on the rims.
/ FIRST Tractor- Kinda nervous! #18
Hey Little John,
Get yourself a left step and a block heater. We got ours a couple months ago, it's a great little tractor. Still getting use to it. Did you get the SuperSteer?? That step makes it a lot easier getting on and off.
/ FIRST Tractor- Kinda nervous! #19
quote]
A stand similar to this works quite well and cost about $25 for materials.
/ FIRST Tractor- Kinda nervous! #20
THANKS!
John.
Why the 4' mower? should handle 5' easilly with that hp.. if not more.like 6'.
My EX NH 1920 spun a 5' and 6' mower fine.. it was 29 at the pto.. and about 33 at the engine..
soundguy
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A62130)
25' SINGLE AXLE...
2022 John Deere 5055E (A62177)
2022 John Deere...
