First time buyer 35-50 hp and implements
   / First time buyer 35-50 hp and implements #21
YOOPER DAVE
Tier IV Emissions Confusion​
Are new tractors with <25hp Tier IV emission exempt ?
The demarcation is 19 kW engine power output = 25.4794 horsepower.
While Tier IV exempt, tractors with <25.4794 horsepower comply with relatively loose Tier II emission requirements.
Some mfrs note no pollution filter is needed, but tier 4 compliant.
Most manufactures can meet Tier IV requirements without a Diesel Particulate Fillter up to about 27 horsepower via engine design and injection timing.
(Diesel Off-road emission standards are uniform in developed world.)
Then there is a horsepower gap.
Beginning about thirty-three horsepower most tractors have Diesel Particulate Filters.
If there is no DPF there is an alternative incendiary technology to burn off very fine particulates (soot). Sometimes exhaust heat is elevated all the time, sometimes periodically.
Diesel particulates must be burned. THERE IS NO FREE LUNCH.
Tire wear and tire replacement will cause as many headaches and more expense than DPF for most long term compact tractor owners who comprehend their tractor's Operator's Manual and follow DPF procedures.
Many small property users regenerate only once per year. This creates regeneration procedure uncertainty in itself. (Regeneraton occurs every ~~60 engine hours. Non-commercial users average 80 engine hours of tractor use per year.)
Somebody asked my budget...I don't have a specific one. I'll pay what I have to, to get what I need, but I don't want to pay more than I have to. I always try to find the best value for my money, I rarely regret my decisions that way.
I have prepared to spend about 35k for a high 30s HP Kubota or JD with a FEL, though I admit it was a bit of sticker shock when I first started looking. I can go a little higher if I needed to, but it doesn't sound like that would be necessary. Would love to spend less, but don't want to buy something and be wishing I had spent a few more grand to get something a little better.
   / First time buyer 35-50 hp and implements #23
Define better. Many other brands offer more weigh and capacity
So I just stopped by the JD dealership and took a look around. They have a lot of compact tractors they are trying to move including some 2022 models so they 3032E at 4k under list. Total package for tractor, FEL, 5' tiller, and 5' RC is 31k with 0% financing for 4 years or 0.9% for 5 years. So I think I'm going to do that.
   / First time buyer 35-50 hp and implements #25
I was going to suggest sticking with Deere because they are the closest dealer to you.
I think you made a good choice, but if there is a 3038E available.....Maybe?
Yeah, I looked at that, but they didn't have nearly as many 3038s to move and no 2022 models so the discounts weren't as good. I think it was about a 4-5k difference when the difference between those models is usually around 2k. I may regret it, but I think the 3032 will be enough tractor for me. I'll let you guys know how it performs with the tiller.
   / First time buyer 35-50 hp and implements #27
Once the ground is broken, I think it will handle tilling just fine. The biggest factor, I think, in this HP range and tiller size, really is the soil condition. On virgin ground, my 4820 grunts with a 6' tiller. Once loosened, it doesn't know it's back there.
   / First time buyer 35-50 hp and implements #28
I have similar usage. I have 12 acres, about half in Christmas trees, plus about an acre of lawn. My hour usage is similar. I do it all with a Kubota 2301 and, though it's a great tractor, it's a bit underpowered when I hit some of the heavier soils with the rototiller.
If it were not for using it on the lawn, where weight and size are a factor, an L with a bit more horsepower would be nice.
BTW, I chose Kubota largely for the dealer service we have here, as well as the 0% financing.
   / First time buyer 35-50 hp and implements #29
My new tractor is a 1974 MF 40 construction tractor. I have owned it for 15 years of hard use. I have done very little to it and most repairs were damage from moving felled trees. I have worked circles around everyone I know who has bought new tractors for similar work because they seem to have a lot of service issues. It is a very stable tank of a tractor that has kept on ticking.
   / First time buyer 35-50 hp and implements #30
What is a D19? A Caterpillar crawler?
Have you owned or operated a Three Point Hitch equipped tractor in the past?
Are you aware of how unstable TPH tractors are?
Is your land FLAT or will you operate on sloping ground?
Do you feel qualified to do your own tractor service? (RE: Rural King)
My anticipated use is 50-100 hours a year.
This is the operating hour range when emission control equipment may be cranky. If you can find a good 2012 or older used tractor with 35-50 horsepower it will predate emission control requirements. (DPF = diesel particulate filter + paraphernalia.)
Here are 20 tractors listed on eBay within 100 miles of Muncie, closest tractor first:
Are you aware Harry Ferguson designed the three point hitch because he was tired of seeing farmers killed when tractor pulling drawbar drawn implements overturn and kill the operator? He on a handshake agreement with Henry Ford allowed Henry to use it on the 9N in 1939. Harry Ferguson work with Black and David Brown in England but could not really succeed until he started the TE series in England and the TO series in the US.
The Black Tractor - Ferguson Family Museum
As for three point hitch useage the operator must be aware it can make the front end light and may need counter balanced with weights or even a loader.
And the D19 Allis Chalmers was the first diesel to use a turbocharger.
   / First time buyer 35-50 hp and implements #31
I have about 10 acres and am planting it out in Christmas trees. I have gotten by for my first few years borrowing my dad's D19, which is more than I need, but available. I finally am in a position to get my own equipment, and am looking for all the advice I can get.
My anticipated use is 50-100 hours a year split between mowing, running a 4'-5' rototiller, pulling my single seat transplanter, and some FEL work spreading gravel, mulch, etc.
The rototiller and transplanter are only used about 2 days a year when I plant the trees.
So, like I said, I don't anticipate heavy use of this tractor, but I also don't have time to be fixing something that breaks regularly as my day job keeps me pretty busy.
JD has the only dealership in the immediate area, but I have Kubota, MF, New Holland, and IH all within an hour.
I have looked at the rural king tractors, and they certainly seem to be the least expensive. I can get the 37 hp model with FEL, tiller, and rotary cutter for about 30k which is a little less than a similar Kubota L series with just the FEL prices at 33k and way less than the 45k prices I'm getting for comparable JD tractor with no implements.
I know least expensive isn't always the best buy, but it is tempting to go with rural king. That being said I'm leaning towards Kubota as their 0% financing is attractive. I could buy it outright, but I'm also getting ready to build a house, so using someone's else's money is a plus.
Thoughts?
My thought is a used tractor. A Ford 4000SU or 4000 if you are using a FEL due to the robustness of the front axle. The Ford 3600 has less front axle but can take an FEL. These are 50 year old tractors but parts are still available at a good price because they are revered by Punjabi farmers, so a licensed model is still produced in India. These tractors were made when gears were larger and had superior metallurgy and bearing support than today's "compact tractor". The real problem with these old 2WD JDs, Fords, MFs is the scale of farming here has grown so large, that FEL on tractors can't keep up with a Bobcat, and field work is done by closed workstation in the 50+ range. So many old 2WD tractors, <50HP do 72 rotary cutter, finishing, grader and subsoil with no problem are still out there. I use mine primarily for logging, and nothing will test your power and traction than a trunk of a wet oak or maple being pulled up a hill. for the $30-50K you budgeted, you could spend 20K for a used tractor AND a used Bobcat and use both at what they do best.
   / First time buyer 35-50 hp and implements #32
Don't know how popular MF tractors are in your area, but I would recommend a MF 135, 150, 230, 245, 240, 250 (38 to 45 hp) or similar model not a 235 though. Yes the are OLD but they are tough dependable tractors and as a rule used parts if needed are readily available. The three cylinder diesel is very fuel efficient, dependable and cheap to overhaul when needed. The Ferguson draft system can't be beat. If you can find a low hour tractor that has been taken care of it will give good service and last a long time.
Those listed would accept a MF 232 or 236 Quick attach loader, or even aftermarket loaders, and are usually equipped with a two stage clutch or independent PTO.
But that is my advise and opinion.
   / First time buyer 35-50 hp and implements #33
You might want to specify a "reverse tined" Tiller. Having the tines rotating in reverse will help dig into the soil while you are going forward. 5' tillers really are not that heavy and a standard tph will have a Tiller bounce up on hard ground.
Just my two cents.
   / First time buyer 35-50 hp and implements #34
Allis Chalmers D 19
   / First time buyer 35-50 hp and implements #35
Take a look at the Massey Ferguson 1840M...if you can find one.
   / First time buyer 35-50 hp and implements #36
Thoughts?
Thoughts?
I had a good friend asking me the same question a few years ago. He was debating John Deere, Massey Ferguson and Kubota. I told him go shop the dealerships and let them know you’re serious about buying and want to rent one for a couple days to try it out. JD and MF dealers were pricks and told him to go look at them in the parking lot. Sales rep. didn’t even offer to go outside with him. Kubota set him up with a rental then waived the rent when he bought from them. A good dealer will be worth more than any front end savings when you are having issues. In your area it may be another brand but shop dealerships that will treat you right.
   / First time buyer 35-50 hp and implements #37
So given this information, I'll say again, find your nearest Yanmar dealer. Hopefully it's less than an hour away.
Go sit on an SA425. I run a 5 ft tiller behind mine no problem. It runs 5 ft implements no issue. With loader and tractor it probably weighs around 2300 lb.
The fact that it's a lightweight tractor is the reason I bought it. You will have guys on this site tell you that you have to have a heavy tractor to do work. Which is BS.
If you're going to mow with it you don't want a real heavy tractor if you're going to do dirt work and you want more weight add it with rear ballast box front weights whatever.
If you have a TYM dealer nearby also look at them.
Now that you have looked at John Deere and Kubota you will not be sticker shocked by t y m or Yanmar
   / First time buyer 35-50 hp and implements #38
Okay I made the above post before reading this. This sounds like a really good deal for a John Deere and those implements.
I think you'll be good with that decision. you'll be happy with it.
Post pics when you get it.
   / First time buyer 35-50 hp and implements #39
any follow up from the op? would be curious of his thoughts now that he has made his purchase?
   / First time buyer 35-50 hp and implements #40
I would buy something that I could work on. Not sure what size that you want but maybe an older 3610 or so. I bought a 5610 4X4 15 years ago and had the motor rebuilt immediately. New valves, sleeves, pistons, turned the crank, etc.....It has worked great and I would recommend this approach. Its a little expensive on the front end. I think I spent around 13K total at first, but the cheapest 5610 that I could find running with reasonable hours was about 25k then.... So if I look back if I had put an extra 10-12k in it from the beginning I would have had a very nice tractor with a new motor ,tires , paint etc.....Just an idea. By the way it only has 5 wires in the wiring harness, so no computer....
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2016 Nissan Quest Van (A59231)
2016 Nissan Quest...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
UNUSED SDLANCH SDLE20 EXCAVATOR (A60430)
UNUSED SDLANCH...
