First time buyer 35-50 hp and implements
   / First time buyer 35-50 hp and implements
any follow up from the op? would be curious of his thoughts now that he has made his purchase?
Yep. I have about 10 hours on the tractor now. I haven't used the rotary cutter, but have used the tiller on about an acre. It tilled fine with a 4-6" depth, the tractor bogged down slightly when I got into an area that was still a little wet, but even that just required a slight let up on the pedal.
The FEL controls are not in a very ergonomic position, they are much better on the R models. It's not a big deal for me, but if I was running the FEL for a couple hours at a time, I think the position would start to hurt. The FEL doesn't take quite as big of a load as I hoped, but it is adequate. It can pick up about a half bucket load of gravel without any problem, but if you try to get much more than that it has a tendency to run out of curl power when you are trying to initially pull it out of the pile. I used it to pull my tree setter off the back of my pickup this morning and it did great. Just for reference, I did not have the height to strap the setter to the FEL and lift it, I had to pick up the end with the bucket and drag it off the tailgate.
My wife finds it very easy and enjoyable to operate and that's a big plus. It means she wants to go out and do all the tractor work and I can get other things done. The hydrostat is a big contributor to that.
Overall, I'm very happy with my purchase. While a little taller tractor, or a little more power would be nice to have, I do feel like with the discounts, I got a really good value for my money. I think I said this in an earlier post, but since I got the previous model year, they gave me 4k off list so I paid 26k for the tractor and FEL.
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
CAT Chassis Only (A59076)
CAT Chassis Only...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
