cab project
/ cab project #41
with that kind of motorvation and the ability to never run out of energy, you have now solved all of your driveway clearing problems......
well, son, you'd better go out and get ole' yellar to clear the drive
/ cab project #42
well i got a little done today went & picked up 2 sheets of steel 16-gauge 4'X8' to skin the cab. i got a little side tracked when a customer came in & needed a snow plow built for a 100 ton rock truck. i couldnt say no he said he would help me,so an our later we had it done & it works great the customer was very happy. now i did get the one side window skinned still need to cut the opening for the window. does anyone know if there is a minimum radius for rounded corners for glass.i would like to round the corners so the gasket is all one piece with one seam where the two ends will meet.
Glad to see that your back at it, its really starting to take shape with
the skinning of the cab. I don't know about the minimum radius for
rounded corners for the glass. how thick of a gauge of metal are you
going to use for the top? I haven't bought any metal yet for mine, i
have been measuring for metal and still doing a lot of thinking about
it before i start.
From the looks of the pictures your customer was happy with his
100 ton rock truck with a custom snow blade, and he was doing a great job too. I could not see his face but i say he had a great big smile. :D
Great job and keep us all posted.
/ cab project
finished the window today, cut the window area out & used the blank to do the bottom window area still need to get a latch for the window. i plan on useing 1/8" for the roof.
/ cab project
more progress today finished right side and back window.
/ cab project #46
Looks great Dirtnut! I would think 18ga - 16ga would be more than adequate for the roof, especially if you put some light weight bracing (1/2" square tube) on the underside to contain the vibrations.
I think 1/8" is overkill and will add to the overall weight in a negative manner with a higher center of gravity.
Keep the picture coming!
/ cab project
left side door upper swing window done.left side rear window done.will finish lower window on door tomorrow & front window. anyone know how much surface area is needed for wiper motor to mount on.
/ cab project #48
It all depends on the wiper motor and its mounting bosses.
/ cab project #49
Now its really starting to look like a cab, looks like you will have good visibility from the inside. I like the picture showing the door that will have two windows, rather than one big piece of glass.
mjncad is right, I think that jc Whitney sells some compact wiper
motors that has an on and off switch right on the motor.
You probably could do a search on the web to see want different sizes is out there.
Glad to see the pictures and great job.
/ cab project
finished the bottom window on the door today. decided it needed to go back on the tractor to fit and finish sheet metal and decide if i want the wiper at top or bottom of window it will go to the bottom. it wont obstruct my view there it will on top when using loader up high. i think when i skin the front i will weld what i can. then i will drill and tap holes 1/4" in the cab frame to bolt seperate panels on that can be very fine tuned to the contours of the tractor housing,will do this with the floor panels to this will also give easy access to the tractor if problems pop up. now i need to find 2 wiper motors front & back. i would like to use kioti wiper motors but cant find any info on them.
/ cab project #51
Nice job! It really looks good on the tractor, i did a search on the wiper motors that you want and had no luck.
The only place i know is jc whitney.
how much do you think your cab weighs right now without the glass?
/ cab project
i looked at jc whitney the ones i saw were replacement for old vacume wipers. are these the ones you are talking about. they look like they would work great with one 3/8 hole for mounting. but how do u know about the sweep angle it says 90 degrees on the motor but how do u translate that to wiping the window as far as will it work & which length arm to get.does the motor not matter & it is based on the arm & wiper blade length. i will check surplus center. i am guessing the cab weighs 200-300lbs. well i am off to get welding supplies ran 12lbs off wire through my welder already.
/ cab project #54
I went back on jc whitneys site, i don't know which arm to get.
When you go to the page on wipers, go down until you see one that
says (HEAVY DUTY) $43.99 it doesn't say anything about replaces old
vacuum style motors. And it says you can mount it above or below the windshield.
Then go on down the page until you see (SINGLE SPEED MOTOR)$46.99--$48.99 It can be mounted above or below the windshield also And it says nothing about replacing old vacuum style either.
But it is 12 or 24 volt.
When you click on one you can see where people have asked questions about the motors, one person wanting to know if you could put one on a boat windshield, you can read all the questions.
But on the (SINGLE SPEED MOTOR) someone asked about putting one on a van, and it said this motor was for (CUSTOM USE APPLICATIONS).
/ cab project #56
I had a '57 Chevy step van that came with vacum motors for the wipers. I replaced the vacum motors with the ones from JC Whitney. They worked great.
If I remember right the arms I bought had set screws so they would fit any size shaft. Just had to set them so that the sweep was where I needed to see through.
In my case there was a tube to run the shaft through but that would be easy. Just make sure you put a rubber washer under the nut on the outside so you don't get water running down the shaft and into the motor
/ cab project
i did check out jc whitney i think i will try one of the wiper motors. they look like they should work.
/ cab project #58
Very impressive job Dirtnut. Maybe someday I will get the time to build one of these myself. A couple of questions: Did you you do any mock up with wood or use any software to come up with the final frame design. Also, how is the cab mounted to the machine. Did you have to make special mounting pads which to bolt to the tractor or add any cross members to accomplish this. Maybe you could show pictures of how this is done? Great job, look forward to the completed unit.
/ cab project #59
Dirtnut, I did a cab project about 10 years ago for my ford 1310. I made the cab in several pieces so I could remove it in the summer as I have trees to mow under. I made it an awfull lot like yours with only one door. I now have a kubota b7510 and retrofit it to this tractor but I made 2 doors this time as I was not happy only being able to exit one side. I used 3/4x3/4x1/8 square steel tube with aluminum sheet to skin the top and partly down the sides. I went to the local wrecking yard and and got some windows out of a micro bus. I used plexi glass to skin the rest of the cab all windows and skin are very dark and makes it easier on your eyes in the winter sun. The front window is clear glass to see at night. the door windows are from a jitny from work. I atached all the windows and plexiglass with self drilling and self tapping screws.
viewpic.php
[/URL][/IMG]
viewpic.php
[/URL][/IMG][/IMG][/IMG][/IMG]
So is 3/4 x 3/4 x 1/8 a strong yet light enough tube to go with? We will be starting our cab in the spring, once it is warm enough.
/ cab project
drivadesl-thanks.i work consruction operating heavy equipment so we are on our seasonal shutdown till the weather breaks so i have the time now to work on it.i did not do any mock up.i thought about doing one with wood but decided it would be a waist of time because what ever i did with the wood, i would be repeating with the steel so i went right into it.the design was from my mind seeing other cabs i did what would work for my tractor. most cabs have a basic design so its a matter of fitting the tractor and adding or deleting what you want. if you look in i think my first post i have pics of the mounting brackets if they are not clear enough i can take better close ups. the front vertical rail has a stud welded in the bottom which passes through a plate welded to the bottom of the loader subframe then is secured with a lock nut.above that about a foot i cut a hole in the verticle rail on the inside & welded a nut flush in the rail, this is bolted to a piece of angle welded to the loader subframe.on the back i cut a piece of plate steel to match the rops frame welded it to the cab frame then it is bolted to the rops.
WilliamBos- that depends on your design, i am not an expert. if it is framed for just holding glass it should be ok. if you are eliminating the rops it should be heavier.i will not have the upper part of my rops so i went with heavier higher strenght steel and doubled the supports in the back at the rops. i also have 6 places where it is bolted to the tractor.
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
PALLET W/ FAN, CHAIN SAWS & MISC PARTS (A64278)
PALLET W/ FAN...
2018 Toyota Camry Passenger Car, VIN # 4T1B11HKXJU524473 (A64557)
2018 Toyota Camry...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
